Results 1 to 13 of 13
  1. I am trying to compile a time lapse video and keep it short as possible with out losing frames.
    I used timelapsetool to create a video from all my stills, it has a 60 fps option but it removes every other frame and the video is really 30 fps
    so my next idea \ hope is to keep timelapsetools output to 30 fps and then convert that video to a true 60 fps video and half my playback time.
    any suggestion ?
    maybe another time lapse program or a true 30 to 60 fps video converter as i want the video to play faster
    Thanks.
  2. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    With avisynth
    assumefps(60)
    If your video is 29.97fps and want to double that you may consider
    assumefps("ntsc_double")
    ^which will give you 59.94fps
  3. Many containers let you set whatever frame rate you want.
  4. thanks for the heads up, this seems a bit complex as its script based. is there a prefered front end gui interface that can be used and if so will this be a basic option or will a custom script be needed?
  5. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Try here: http://www.spirton.com/convert-videos-to-60fps/
    I use for 4 years, almost perfect.
    Claudio
  6. Cauptain, that whole page to which you linked is about interpolating new frames to get to 60fps while, at the same time, keeping the length the same. acem77 wants to keep the same framecount but double the speed (cut the length in half).
    If you were suggesting an 'easy' way to implement KarMa's suggestion of AssumeFPS(60), I think you should have been more clear about it.
  7. For AVI use AviFrate. For MKV use MkvToolnix. For MP4 use Mp4Muxer or Mp4BoxGUI. All of those will work at the container level without reencoding.
    Nov 2002
    You can do this in Virtualdub. Under Video > Frame Rate > Source rate adjustment (change to slow down or speed up) > Frame rate conversion > Process all frames > Convert to fps (set to desired frame rate) > OK.
  9. Originally Posted by DarrellS View Post
    And if you set Video -> Direct Stream Copy there will be no reencoding, just a remux. AviFrate is faster though, as it writes directly to the file's header.
    Keep in mind that all the header patch, remux options will lead to the audio getting out of sync since the audio isn't sped up along with the video.
  10. thanks for the updates, audio sync in not an issues as i want that to stay the original speed and it will be back ground music.
  11. I have .mp4 files and tried Mp4Muxer, Mp4BoxGUI and AviFrate.
    Mp4Muxer does not seem to be for my mp4. Both do not let me select over 30pfs? am i using these correctly?
    AVifrate does not support mp4s.
  12. Originally Posted by acem77 View Post
    Just type it in rather than using the pulldown.
  13. I had no luck with any gui stuff listed here but i did this with success. now i have to see the if there is a easier way to encode audio\music with minimal head aches.
    http://blog.philippklaus.de/2014/07/changing-the-framerate-fps-of-an-x264-mp4-movie-fi...t-re-encoding/
    change the 30 to 60..
    step 1
    MP4Box -add source.mp4#video -raw 1 -new test
    step 2
    MP4Box -add test_track1.cmp:fps=60 -new dest.mp4
