I am running some test conversions of vp8 encoded media and wow it seems like vp8 taxes my CPU (Phenom II x4 955) a lot more than h264 at a similar CRF setting. The Phenom is just the workstation that is running the tests.
I am running through some beta testing of some software that transcodes video on the fly for streaming and their defaut for vp8 is 4. They suggested running it up to 10 to see if that speeds things up. Those settings for an h264 encode would be ridiculous for streaming media. Is the scale different for vp8?
I am running some test encodes through Handbrake right now. I am converting the first 10 minutes of a 1080p digital copy of The Incredibles and down-rezzing to 720p at with a CRF of 22. I am getting around 18-20 fps. Normal/Abnormal?
Of course. Judge by bitrate (file size) of the resulting files.
Nobody can tell you for sure because there is a 100 fold difference in speed between x264's fastest (ultrafast) and slowest (placebo) presets and you haven't said what x264 settings you're using. But that sounds about right for the middle presets.
DVDFab 9 CRF, Handbrake/Vidcoder x264 CRF
By hogger129 in forum Video ConversionReplies: 10Last Post: 30th Dec 2015, 10:51 -
Playing H264 - MPEG-4 AVC (part 10) (h264) Stream
By SamirD in forum Software PlayingReplies: 1Last Post: 13th Jul 2014, 12:50 -
Encoding For Better Quality? Codec: H264 - MPEG-4 AVC (part 10) (H264)
By derek123 in forum Video ConversionReplies: 7Last Post: 20th Jan 2014, 04:01 -
Re-encode using CRF lower than source's original CRF
By Anonymous54873 in forum Newbie / General discussionsReplies: 13Last Post: 13th Jan 2013, 20:40 -
H264/AVC B-frames in cartoons
By DrDeceit in forum Video ConversionReplies: 11Last Post: 1st Oct 2012, 21:27
