Ok, im kinda new to this whole VCD thing, but when i try and extract and save the audio to a WAV file it says
"Error initializing audio stream decompression
The requested conversion is not possible
Check to make sure you have the required codec"
What codec does it need????????
well, i solved my little audio problem, just had to download the older version. Now, how do i handle multiple files on 1 cd. Like Lord of the Rings is 4 files (2 on each CD), what do i do with the source range settings on each 1 and how do i go about maybe combing these files into 1 big mpg. Im reading the guild but it only give instruction on 1 little mpg. I have 4 huge files. Thanx guys
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
No codec available when audio loaded in VirtualDUB
By Bucic in forum AudioReplies: 4Last Post: 27th Nov 2010, 18:13 -
Audio Codec after Synchronization
By Aurlito in forum Software PlayingReplies: 0Last Post: 13th Mar 2010, 11:47 -
need mpeg audio codec?
By tomm2000 in forum Video ConversionReplies: 7Last Post: 7th Sep 2007, 21:34 -
Lossless Audio Codec Comparison '07
By Tab in forum AudioReplies: 8Last Post: 3rd Jul 2007, 02:08
