I took a DVR recording from USB and ran a Quick Stream Fix in VideoRedo, saving it to a .TS file. I then removed the commercials and saved the new video as a .M2V file (with the program saving a separate .AC3 file as well). I then bring this into DVD Lab Pro to add chapters and hit compile. However, the compile aborts as soon as the muxing starts. The verification log reads as follows:
Does anyone know why this is happening? The streams are compliant and I have done this before with other DVR recordings without issue.Code:*** DVD Lab Pro Verification Log *** 1 - 17 - 2016 -- 22:21:21 ************************ * * * VMG Verification * * * ************************ Number of VTS - 2 Number of Menus: 2 Menu 01 - Type - Dummy Menu 02 - Type - Dummy Number of imported VTS: 0 ************************ * * * VTS Verification * * * ************************ <<< VTS Number 1 >>> Number of Titles: 1 Title 01 - Type - ES or PES Segment 1, Video File C:\Users\RonJ\Desktop\DVR\Stream.m2v Frame Size: 704 X 480 Frame Rate 4 [1--23.976, 2--24, 4--29.97, 3--25, 5--30] Aspect Ratio: 43 [43--4:3, 169--16:9] MPEG Video Type: 2 [1--MPEG 1, 2--MPEG 2] Chroma: 1 [1--4:2:0, 2--4:2:2, 3--4:4:4] GOP 1, size - 271369 GOP 2, size - 49982 GOP 3, size - 508107 Segment 1, Audio File C:\Users\RonJ\Desktop\DVR\Stream.ac3 Audio type: AC3_Mot, Channel: 2, Sampling: 48000, Bitrate: 192000 Segment 1, Subtitle File : None Number of Menus: 2 Menu 01 - Type - Dummy Menu 02 - Type - Dummy ************************ * * * Status Messages * * * ************************ Start building Video Title Set ( VTS ) ... - 2001 Title - 1 Start building VOB streams - 2210 Muxing elementary streams is in process ... - 2220 Initializing audio packets ... - 3005 Initializing AC3 (MOT) audio packet ... - 3030 [INFO] - No subtitle stream is provided - 3739 Verifying Closed Caption file is in process ... - 3750 Muxing is in process ... - 2300
Yep, the streams look compliant. Maybe run the m2v through videoredo quick fix again.
Or try another authoring for just this video. Like dvdstyler, dvdauthorgui,etc and see if they can make a dvd-video without problems.
Compile from source code
By Nurz in forum ProgrammingReplies: 3Last Post: 27th Jun 2015, 10:26 -
Please compile this! ( please read)
By ben45 in forum Video ConversionReplies: 3Last Post: 13th Dec 2013, 09:31 -
DVD Lab 2 pro won't compile/burn video project
By rad0909 in forum Authoring (DVD)Replies: 3Last Post: 19th Jun 2013, 12:11 -
DVD lab pro dvd compile doens't work well
By glenn0811 in forum Authoring (DVD)Replies: 6Last Post: 30th Oct 2012, 06:08 -
[DVD Lab] can not function in the "Compile DVD ..."
By dom61 in forum Authoring (DVD)Replies: 2Last Post: 27th Aug 2011, 12:07
