Hi, Im new here, so if i missed this same question when i searched the index, please forgive me.
I have about 600 blurays, and have been using handbreak to rip them to mp4. then synch them to my iphone to watch while traveling. I dont need super excellent video quality as the dvds i have ripped look pretty great on the iphone and the bluray quality just takes up too much space. Handbreak plus anydvd doesnt always work. Sometimes only about 15-20 minutes of the video gets ripped. Not to mention that Handbreak takes forever when doing blueray.
so i guess what i need, is a way to rip bluerays to mp4 in file sizes about 2gb or less ( dvd rips to about 600mb)
any suggestions ?
Try DVD dfab, it's not free
There is a trial version, don't remember if the trial does does blue ray
The PAID version, does do bluray
Makemkv gets mentioned a lot, it might do bluray -
MakeMKV works with Blu ray but doesn't process or shrink the size in anyway. You would then have to find a program to shrink to a suitable size and then to mp4 say using MkvToMp4 https://www.videohelp.com/software/MkvToMp4
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
If you are interested in speeed primarily, DVDFab is one of the fastest programs I've tried using default settings. You can set up Handbrake or Vidcoder to equal that speed for free if you just explore their settings.
Anydvd is easily one of the best decrypting programs available, so keep it updated and keep using it.
Encodes stopping prematurely is most likely a problem in your system, not the software that you are using. -
Thanks for all of the replies. I took the advice from Kerry56 and tweaked the settings in Handbreak. now the mp4 file is down to about 2gb from 20. this does take about 45-65 minutes while a dvd only takes 15-20 minutes, but then a blu ray does contain way more data, so I'm happy with that. Also, the partial encoding disappeared ( i'm guessing something in the settings were messed up that i unknowingly fixed )
I'm going to watch handbreak tutorials on youtube to be more educated and possibly GIVE answers to its use as opposed to asking for them next time. Again thanks.
How to rip multiple subtitles into a MP4 file from a BluRay movie
By Jakob Olsen in forum SubtitleReplies: 4Last Post: 5th Jun 2014, 09:03 -
Best video bitrate for a 2 hour movie with small file size?
By JackSpicer0 in forum Newbie / General discussionsReplies: 5Last Post: 20th Feb 2014, 16:47 -
Best scheduled recorder software with small file size ? Hauppauge colossus
By luigi41 in forum Video Streaming DownloadingReplies: 15Last Post: 29th Sep 2013, 23:13 -
Suspiciously small 'projected file size'
By patryk8820 in forum Video ConversionReplies: 2Last Post: 30th Oct 2012, 15:30 -
Converting IFO file DVDs to M4v for Iphone viewing
By anotherhappyday1 in forum Video ConversionReplies: 1Last Post: 22nd Feb 2012, 14:41
