What exactly is a single inserted frame? What does it mean for the authoring process? Are they easily identifiable after capture and is it a sync issue that needs to be fixed after capture?
When you capture at a fixed bitrate but the capture device isn't giving you frames fast enough, the capture program will insert frames to make up for the difference. The inserted frames are usually copies of the last frame received.
Cropping a single frame in a video
By Akai-Shuichi in forum RestorationReplies: 2Last Post: 22nd Oct 2015, 09:25 -
Superimpose video frames to single still frame
By BobAchgill in forum Video ConversionReplies: 6Last Post: 19th Nov 2014, 16:01 -
Batch create single frame videos
By moosehunter in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2013, 22:14 -
Screen capture black frame single images.
By Innomen in forum Newbie / General discussionsReplies: 0Last Post: 30th Jun 2012, 11:30 -
question re: breaking up and joining a single frame (or GOP)
By unclescoob in forum RestorationReplies: 9Last Post: 12th Jun 2012, 16:00
