I used Aegisub for timecoding. When i change the font to "arial" to "avenir" there is no problem, but when i export it changes to "arial" again.
Then when i embed the subtitle i have an arial fonted subtitle in the hardcoded mp4.
I want to use "avenir" font on the hardcoded subtitle. Is it possible?
Thanks for your interest already!
Results 1 to 14 of 14
Are you exporting to ass subtitle? Other formats may not support any font settings.
How do you hardcode the subtitle? -
You could try VLC Media Player then, open the video with the subtitle, under File->Convert/Stream choose a profile(like h264 video/mp4), click Customize, under Subtitle see if you can choose the subtitle track and choose Overlay subtitles on the video. Apply. And last save as file
Use method from PS3 (but also from DVD\BD\DVB etc) - render subtitles as group of pictures then you can use any font you like - this is renderer independent method.
http://www.makeuseof.com/tag/play-avi-files-subtitles-playstation-3/ -
Okey. Don't give up. You have several options now.
Best subtitle font?
By flickerx in forum SubtitleReplies: 21Last Post: 14th Feb 2019, 17:36 -
Embedding .ass subtitles to mp4 files
By MMFG in forum SubtitleReplies: 5Last Post: 2nd Oct 2014, 02:46 -
Embedding TWO Subtitle Tracks in Video
By Chenn2 in forum SubtitleReplies: 13Last Post: 26th Jan 2013, 23:20 -
Qt + Mac OS X + mplayer embedding,...
By Selur in forum ProgrammingReplies: 0Last Post: 23rd Apr 2012, 14:22 -
Subtitle font color
By stem300 in forum SubtitleReplies: 3Last Post: 12th Dec 2011, 14:30
