The colour's already wrong, I figure it can't hurt to at least see if it can be done.
It's on a scene change, there doesn't seem to be any blending yet it's paler than the previous frame.
I've never found anything.
Are you looking for an automatic solution, or are you willing to make your way through the video manually fixing the scene changes as you go along?
... Don't you read doom9? I'm writing a powershell script to split episodes into scenes so I can work on each scene individually. This particular frame is actually a single field, although I'm pretty sure the discolouration begins in the previous frame although it just looks like noise there though. The discolouration could have just bled there from the final frame through filtering or referencing maybe... not sure.
You know I do, so I'm not sure the point of the question. And I know nothing about powershell scripts but I know how to get rid of discolorations on either side of scene changes, but only by going through the videos from beginning to end. Nothing automatic. If you split the videos into individual scenes, I know how to get rid of the discolorations at the beginning and/or end of those scenes. jagabo already mentioned one way:
By which he may be referring to the AviSynth FreezeFrame command. Both he and I know another way that saves much of the writing FreezeFrame requires. So, again, if this is something automatic you want, well I know of this which duplicates all scene change frames with the frames both immediately before and after them. Personally, I don't find it so useful because it always duplicates the frames and sometimes duplicates frames you don't want replaced (the dfactor setting is important) while I prefer something that duplicates only the ones needing replacing. Maybe you want them all replaced, in which case you might like it
It needs RemoveDirt:
A=Last
prev = A.selectevery(1,-1)
next = A.selectevery(1,1)
SCclean = A.SCSelect(next,prev,A,dfactor=2.0) # 2.0 ~ 5.0
return(SCclean) # return(restore) for NO scenechange cleanupLast edited by manono; 17th Jan 2016 at 19:03.
How to find out frame exposure time in a variable frame rate .mov file...
By bananas100 in forum EditingReplies: 5Last Post: 24th Oct 2014, 20:18 -
is there algorithm that can make for me the frame maping for RemapFrames()?
By gil900 in forum RestorationReplies: 0Last Post: 21st Feb 2013, 17:57 -
how to make a video "stickin" to a certain view (frame)?
By Srivas in forum EditingReplies: 17Last Post: 14th Jan 2012, 10:11 -
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 13:24 -
Does changing frame rate make audio out of sync?
By aznbennet in forum AudioReplies: 2Last Post: 11th Sep 2011, 03:32
