Hi I would like someone if you can tell me why when I want to do integrating subtitles GREEK encoded with utf-8 me to MKVTOOLNIX with a view to seeing the movie on my television Subtitles are Chinese while with external subtitles plays normally on television what I do wrong with MKVTOOLNIX?
	1: Are you positive what you're seeing is Chinese? I know I wouldn't have a clue if I saw it.
 2: Chinese characters are 2 to 3 bytes long in UTF-8, Greek are 2 Bytes
 3: Have you tried it using software players in your PC?
 4: Did you make sure there was a BOM in the UTF-8 files?
 5: what are you seeing exactly? Are ALL characters "Chinese" or just certain ones?
	All characters are Chinese, the bom how to find it in utf-8 files and do not know even know what is the BOM and also I have tried it on my computer and is perfect only on television I have problem before little I did integration with convertxtovideo take a while He looked but the subtitles normally the 2 bytes that we use;
	If it plays in a software player but not on your TV then the problem must be with your TVs Matroska demuxer and not with the file.
	and what we do in this case; my tv READS MKV files .Ego I think something does not do something correctly in the program MKVTOOLNIX
	Why do I say this because external subtitles utf-8 together with mkv file is played in nearly perfect because the program changes Subtitles that will change them automatically through the mkvtoolnix that prevents to become
	So what you're saying is that there's a bug in MKVMerge, THE official Matroska muxer, and there's a bug in... (is it VLC or MPC-HC?) a player that in all probability has better Matroska support than any hardware or commercial software player available and that that bug magically lets the subtitles get displayed normally despite whatever the MKVMerge bug has done to them.
 And your evidence of this is that your player can happily play subtitles from a completely different format?
  MKV Toolnix Problems - GUI is horribleBy VideoFanatic in forum Video ConversionReplies: 4Last Post: 24th Oct 2015, 23:15
  Adding intro in to an MKV with MKV toolnixBy Nozem013 in forum EditingReplies: 5Last Post: 26th Sep 2015, 15:44
  MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-rayBy Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19
  How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45
  MKV toolNix using AVI demultiplexer to convert VC1By cal_tony in forum Video ConversionReplies: 5Last Post: 30th Nov 2011, 20:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
