Hello again,
It was too good to be true! Until yesterday, multiAVCH was warking like a charm and suddenly is "misbehaving". No matter which project, or settings I load, the Menu's background (image) won't change at all and also, I cannot modify some settings like, for example, the name of the "Title List", which I successfully modified to "Extras", until yesterday! I tried the following: resetting all by default, rebooting my PC, removing and re-installing the program (also with the previous version and then again with v. 771). I even removed and re-installed the required haali (recommended version) and ffdshow, but nothing! So frustrating, but of course, it's not the end of the world.
Has anybody elese encountered the same issue?
Thanks again in advance,
Jiji
Windows 7 64b, Intel Core 2Quad Q9300 (2.50 GHz), 4GB RAM, 1TB HDD, ATI Radeon HD 4650
What i did was make a backup of multiAVCHD.ini when it was working and when it started to bug out i replaced the multiAVCHD.ini i backed up to the multiAVCHD folder in program files.
Thanks for the advice, Johns0. At this point, since mine is not working, I can try to restore my PC to a few days ago. Let's see if it works. TBC...
Windows 7 64b, Intel Core 2Quad Q9300 (2.50 GHz), 4GB RAM, 1TB HDD, ATI Radeon HD 4650 -
Just delete the multiAVCHD.ini first and set your options again to see if it will work again,if it does then save the multiAVCHD.ini from the multiAVCHD folder to somewhere else.
Seems to be working, now. Thanks a million and have a great day!
Hi everyone!
I finally, found out why that was happening and it was caused by me! Let me share it in case someone bumped in the same problem:
In order to make sure that the the playback returned to the main menu, I checked in "Media/Properties" the option "Action after playback" to "Menu/Custom" and pressed "OK". Doing so, the Main Menu gets blocked for editing! All it took was to select "Menu/Default", instead, to be able to edit the menus again.
Hope this helps!
JijiWindows 7 64b, Intel Core 2Quad Q9300 (2.50 GHz), 4GB RAM, 1TB HDD, ATI Radeon HD 4650
multiAVCHD menu background and chapter thumbnail creation
By Delta007bhd in forum Authoring (Blu-ray)Replies: 12Last Post: 7th Dec 2016, 09:19 -
(Avisynth) Frozen image when using Overlay or StackHorizontal
By ephienix in forum EditingReplies: 0Last Post: 2nd Jan 2016, 16:39 -
multiavchd - no background audio
By N3stoor in forum Authoring (Blu-ray)Replies: 2Last Post: 26th Feb 2015, 16:26 -
Background images squashed in MultiAVCHD menu
By blakean99 in forum Authoring (Blu-ray)Replies: 4Last Post: 16th Mar 2014, 19:40 -
Question on DAR and best image size for a pal movie menu background
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 12th Mar 2011, 11:42
