Hi i want to rip my music dvds to mkv but alot of them have the main concert and music videos. I've tried a few program but they all rip the dvds to seperate files. I was looking to rip them all into one file. Can this be done and if yes what software could do this.
It may depend on the DVD. Assuming the music videos are exactly the same format as the main concert, you can probably join them after conversion to MKV.
Try VidCoder. Then AVIDemux for joining.
I don't know of any program that can automatically combine the video files during an encode.
But there are many other options that our members may suggest. -
Does MakeMKV create several mkvs?
Or try join all mkvs with MKVtoolnixGUI after you have ripped/converted. It usually works better than avidemux. But all video properties must be same.
Software Recommendation Please
By golfnut in forum Blu-ray RippingReplies: 5Last Post: 8th Aug 2015, 07:27 -
Any recommendation on audio conversion software?
By pizzaboyUK in forum AudioReplies: 7Last Post: 25th Sep 2014, 05:23 -
Need a software recommendation
By PokerHandfull in forum Newbie / General discussionsReplies: 1Last Post: 2nd Oct 2013, 22:18 -
Recommendation for replication (syncing) software
By lordhutt in forum ComputerReplies: 13Last Post: 27th Mar 2013, 09:12 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19
