Hello,
I'm new here. I've been working on a project to add menus to the latest Star Wars Despecialized Edition in my spare time. I have built the project in Encore CS6 and I'm completely done with it now. I had an issue when I demuxed the .MKV file and added in the DTS-HD-MA files to Encore. For some reason they came in significantly longer than the duration of the film. So I was advised to build with the standard .AC3 files, and then patch in the DTS files afterward in multiAVCHD. I have been assured that I should be able to just patch in the files and reexport the BDMV folder structure without any other changes. For some reason, I can't figure out a way to turn off multiAVCHD's menu generation feature. It destroys my menu structure upon output. Can anyone enlighten me on how to avoid this? I'm also curious if there is a way to replace video tracks? I would like to potentially use a different video track that may have better encoding than the one I'm currently using in my Encore project. Encore, however, doesn't like it. I know it's good because I can mux the .MKV file straight to blu-ray with no issues. Thanks for any help with this! If I get this project completed successfully I'll be releasing the .iso so anyone can have a SW BD with menus. They are not fancy like some of the projects in the works out there but they are effective. I have successfully burned a disc with full menus that does not have the HD audio so if all else fails I can let that one into the wild.
Closed Thread
You can use tsmuxer to just remux to a m2ts.
But I have no idea if you just can replace a m2ts and the original menus will still work.
I will look into it but I don't think that will get me what I want. I need more specific direction about using multiAVCHD. Thanks for the reply!
If i'm already importing the entire BDMV folder, that would imply that the existing menus are part of the equation... My goal is, hopefully to add the BDMV folder, using the button on the GUI, replace the .AC3 tracks with .DTS files, and then reesave the BDMV folder using the Blu-Ray for BD-R/RE button in the output options. All of this has been straightforward, with the exception of telling multiAVCHD NOT to create a menu structure. If there is another way for me to open the BDMV structure and replace the .AC3's with the .DTS's, I'm interested to know if anyone has experience in this area.
Microsoft kills off its Nokia Android phones
By enim in forum ComputerReplies: 4Last Post: 17th Jul 2014, 18:24 -
Adobe kills Creative Suite, goes subscription-only
By roma_turok in forum Latest Video NewsReplies: 16Last Post: 3rd Oct 2013, 20:54 -
Custom menus in multiAVCHD...
By calgunner in forum Authoring (Blu-ray)Replies: 1Last Post: 10th May 2012, 19:35 -
Menus & Chapters Multiavchd
By funkyirishman in forum Authoring (Blu-ray)Replies: 4Last Post: 30th Dec 2011, 12:08 -
Playing AVCHD "BD5" discs incl menus from MultiAVCHD on PC
By R.A.J. in forum Software PlayingReplies: 1Last Post: 5th Apr 2011, 11:44
