Any ideas how to capture the file from this player:
ORCode:https://de122v0opjemw.cloudfront.net/utils/embed.html#otp=20150519vers98312663592b667e0d4e045b0908381066849c2ea440a7a9437a;fullBuffer=1;theme=default
The second video from this page (NOT THE VIMEO)
I tried all kind of FF and chrome extensions, HTTP Watch, Replay media catcher, streamtransport, getflv, IDM, etc etc - For the first time, I'm completly stumped. Nothing picks it upCode:http://superaffiliatesystem.com/01-01-course-expectations/
As long as you tried Replay Media Catcher, the Only Fool Proof way is Replay VIDEO Capture: ( I stopped early just to test)
General
Complete name : C:\Path\de122v0opjemw.cloudfront.netutilsembed.htm l#otp20150519vers98312663592b667e0d4e045b090838106 6849c2ea.mpg
Format : MPEG-PS
File size : 33.5 MiB
Duration : 44s 433ms
Overall bit rate : 6 315 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=12
Bit rate mode : Variable
Bit rate : 6 062 Kbps
Maximum bit rate : 1 000 Kbps
Width : 784 pixels
Height : 432 pixels
Display aspect ratio : 16:9
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.597
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
GOP, Open/Closed : Open
GOP, Open/Closed of first frame : Closed
Stream size : 32.1 MiB (96%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Duration : 44s 417ms
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Delay relative to video : -10ms
Stream size : 694 KiB (2%) -
Screen cap is an option but I have lots of these vids.
How did you pull up this info? which tool did you use?
Impossible to convert file.
By Tenakey in forum Video ConversionReplies: 5Last Post: 10th Jan 2016, 11:59 -
SONY BDP-S350 how to crack region codes from its own menu?
By madfogs in forum DVD & Blu-ray PlayersReplies: 24Last Post: 26th Aug 2015, 18:00 -
audio impossible?
By marcorocchini in forum Newbie / General discussionsReplies: 4Last Post: 27th Apr 2014, 18:10 -
anyone can crack this mpeg-2 file?
By 10362227 in forum DVD RippingReplies: 33Last Post: 12th Apr 2012, 20:25 -
Region crack reversal
By Che_qwerty in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Jul 2011, 08:48
