  1. I have a g60vx had windows 7 worked fine, upgraded to windows 8.1 still worked like a month ago. recently tried to compress some clips and an error would pop up:
    Unhandled Exception
    An Unknown Error has occured.
    Exception:System.Windows.Markup.XamlParseException : Could not load type 'System.Windows.Diagnostics.XamlSourceInfoHelper' from assembly 'PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'. ---> System.TypeLoadException: Could not load type 'System.Windows.Diagnostics.XamlSourceInfoHelper' from assembly 'PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'.
    at System.Windows.Baml2006.Baml2006Reader.InjectPrope rtyAndFrameIfNeeded(XamlType elementType, SByte flags)
    at System.Windows.Baml2006.Baml2006Reader.Process_Ele mentStart()
    at System.Windows.Baml2006.Baml2006Reader.Process_One BamlRecord()
    at System.Windows.Baml2006.Baml2006Reader.Process_Bam lRecords()
    at System.Windows.Baml2006.Baml2006Reader.Read()
    at System.Windows.Markup.WpfXamlLoader.TransformNodes (XamlReader xamlReader, XamlObjectWriter xamlWriter, Boolean onlyLoadOneNode, Boolean skipJournaledProperties, Boolean shouldPassLineNumberInfo, IXamlLineInfo xamlLineInfo, IXamlLineInfoConsumer xamlLineInfoConsumer, XamlContextStack`1 stack, IStyleConnector styleConnector)
    at System.Windows.Markup.WpfXamlLoader.Load(XamlReade r xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
    --- End of inner exception stack trace ---
    at System.Windows.Markup.XamlReader.RewrapException(E xception e, IXamlLineInfo lineInfo, Uri baseUri)
    at System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlR eader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri)
    at System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream)
    at HandBrakeWPF.App.Main() in c:\HandBrake\Hudson\workspace\Release_WindowsGui64\0.10.2\win\ CS\HandBrakeWPF\obj\x64\Release\App.g.cs:line 0
    OK
    I've tried installing different version, night builds and deleting the folders in appdata but there werent any in the folder anyways.
    idk what to do and my hdd is pretty new, like 4 months and it was bought new so i dont have bad blocks.
    PLS HALP!
    Crashes directly you start it? Or when you start convert/compress?
    You could also try VidCoder and see if it works. It's based on Handbrake and is also very easy to use.
