I'm using Nero 5.5.1.8 to convert and burn DIVX files into VCD (and VirtualDub to split them in half). Everything works great, but if the DIVX is in 16:9 aspect ratio, when it's converted to VCD, the picture is scruntched to fit 4:3 aspect ratio. How can I convert the DIVX to a 4:3 "Letterbox" format where the picture is 16:9, but there are black bars above and below the picture to make it fit in a 4:3 screen? Did my question make sense?
Use Panasonic MPEG1 Encoder 2.51 to make VCD-Streams!
You can calculate the new hight like this:
NH = Width of your DivX / 4 x 3
Now NH - hight of your DivX = number of points you should add!
Ex: when you get 80: add 2 x 40 points of black borders -
Thanks for the help, but let me make sure I got this right. If the size of my DivX is 640x272, the formula would be 640 / 4 x 3 which would equal 480. Subtract 272 and you get 208. So I would want to put 104 points of black borders on both the top and the bottom?
Is that right??
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 28th Aug 2008, 23:33 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 00:17
