i have a mp4 video
the audio and video are in different frames how to delay some second of Audio in video
	Does the audio sync error get worse as the video plays or is it out of sync by the same amount the length of the video?
 Which type of error determines the possible fix for the problem.
 If the video and audio are different lengths, then you need to adjust one to the other. Audio length is usually easier to adjust.
 If the error amount stays the same, then you can adjust the starting point or offset of the audio to sync to the video.
 A combination of both can get very complicated.
	is there any software that allow to move audio and video file like as windows movie maker
	You still didn't answer the question redwudz asked,it helps to know so we can give you the software needed to fix your issue. I think,therefore i am a hamster.
	Then you may be able to adjust the audio length as this is the simple way.
 I would try the freeware audio editor Audacity. This all has a bit of a 'learning curve', but it can be a simple procedure.
 Let us know and we can probably link you to some guides or tutorials on how to do this.
	What editing program are you using?
 Depending on what that is, you should just be able to adjust the audio file in the timeline so that it starts several seconds, or however long you desire, after the video starts.
  Global Audio/video Delay SettingsBy eedwards86 in forum Newbie / General discussionsReplies: 2Last Post: 5th Nov 2013, 15:30
  How to fix the audio delay in Avidemux? (or in original .vobs)By Fańch in forum DVD RippingReplies: 7Last Post: 27th Feb 2013, 17:00
  How to fix delay on subtitles?By nemi in forum SubtitleReplies: 8Last Post: 1st Mar 2012, 12:05
  Audio to video delay value on a DVDBy nic2k4 in forum EditingReplies: 20Last Post: 7th Dec 2011, 04:06
  audio/video stutter delay in VLC & MPCHCBy skorpinok in forum Newbie / General discussionsReplies: 1Last Post: 31st Aug 2011, 10:51
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
