Results 31 to 60 of 89
@Adithya @testerics
Hello guys !
Any chance one of you's still around to try and fix 2 small files ?
It seems you are the AMR's last hope of recovery ^^ -
@aiuspaktyn, you have ~25 minutes of your file recovered
Please fix my .3pg audio file sir.
It was produced by Automatic Call Recorder.
Getting error Prepared Failed: Status=0x1 when I try to open in app. -
Thanks a million testerics, you AWESOME!!!
Is there any chance you could recover more of the file?
The Original file was 2.35 MB 38 min and 17 sec, the Recovered is 1.48 MB 25 Min 51 sec.
So there's 12 Min 26 Sec still missing.
Is there anyway you can work your magic and recover this missing audio?
Thanks for everything so far you awesome!!!! -
The recovering process was complete (100% from what you upload). Even if the header of your recording is showing you 38min&17sec, the file was broken after 25min&51sec.
So, nothing to recover after the file was ended prematurely.. -
Hi guys! Sorry for the disturb, I'm an Italian student, yesterday morning I recorded an important lecture at the university with my smartphone and I got a .3gpp audio that seems corrupted. Anyway the lenght and the filesize are detected correctly, I also have a .3gpp.tmp file
Is it possible to recover this file?
https://drive.google.com/file/d/1l9f8l2qD22JTngpHwhp1HuXL3SFAh6PB/view
Many thanks in advance -
@Mich-C, your recovered file is attached. But is 45 minutes of silence, only some noise at the start and the end of the record.
I think it was a problem with your smartphone at that moment, not with the file.. -
Dear testerics,
You are amazing! I am a Taiwanese.
Yesterday I went to my class and took audio recording.
But my cell phone was running out of power and shut-down.
So I got a corrupted (unreadable, bad) *.3gpp file:
https://drive.google.com/open?id=1N2c-P_ArIgUa5IcUIae52jUldOiO_wct
Here's a good one (recorded using the same device) which is longer than the bad one:
https://drive.google.com/file/d/1FLDfEwpD2CfGTgN49sOawgPC1sZKxXIe/view?usp=sharing
ps. I have tried to use HxD Hex Editor to copy the all contents after "mdat" (of the bad one)
and paste-write (not insert) them to the good one, but this doesn't work.
Could you please help me to check this file? Thank you!
Best,
hsz0566 2/12, 2018 -
Hi testerics, what a magical thing you've done!
Thank you very, very much!
I'm very interested in what method you used.
If possible, would you please just share some tip?
(I have worked with this file by Hex editor for hours...but some of you guys have spent years!)
Anyway, thank you very much for your kind help again!
Happy Valentine's Day!
Best,
Song 2/14, 2018 -
Hi, I have a problem opening this : https://drive.google.com/open?id=1PyUcCqtgI8lpQxAYpEU2M9GUj5U9JhWs
Could you please help me with this file? Thanks a lot. -
@jkb0521, can you upload also a good file, from the same device, longer than the bad file (more than 35MB)?
@testerics, Ok, please refer to the required file : https://drive.google.com/open?id=1DO7pBKnnxqP8cZDjiaSg71d_iCZ9w3Sb
Here is your 45 minutes recovered file
.. with greetings from Romania!
Many thanks, I appreciate it very much!
Hello, @testerics! I have an audio file which appears to freeze halfway through the recording.
If it's okay, can you please help me fix the file?
Thank you so much in advance! -
I can try..
Please upload the broken file and a good file from the same device. -
Dear testerics, please help me out to recover my audio, thanks in advance.
plz plzLast edited by Baldrick; 14th May 2018 at 13:59. Reason: File removed.
@TOOMUCH, I attached your file (~34 minutes) recovered
Last edited by Baldrick; 14th May 2018 at 13:58. Reason: Fixed file removed as requested by the user.
@testerics Can you please recover corrupted amr file or describe method?
Hi,
Im new here, i was looking for an answer to repair a .3gp.tmp file, and i havenīt found a program that works.
i was in a car crash a few days ago, and the car camera didinīt complete the video from the crash.
Can anyone give me a hand
Thnks -
@iamedo, can you upload also a good file from the same device?
The size should be more than 16MB.
Can be also usefull in the restore process the model of the camera that was recording.
Please help me i need help bad! 3gp file corrupted but fixed not converting
By kmzilla in forum Newbie / General discussionsReplies: 13Last Post: 2nd Oct 2015, 12:26 -
Cellphone died, corrupted recording. 3gp audio
By ch4osr3v1s3d in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jul 2015, 18:53 -
.amr (audio) file from phone.
By racer-x in forum AudioReplies: 2Last Post: 16th Nov 2014, 18:54 -
Help retrieving a deleted video/fixing corrupted mp4
By Florio13 in forum Newbie / General discussionsReplies: 9Last Post: 14th May 2013, 02:03 -
Fixing FLV with corrupted video
By mjolnir870 in forum Newbie / General discussionsReplies: 3Last Post: 28th Sep 2012, 17:12
