Can I embed a command within an m3u playlist so that the videos in the playlist endlessly loop?
i.e. I have a playlist like the following:
After video5 is finished, I'd like to automatically restart video1, then video2 etc.Code:#EXTM3U #EXTINF:101,video1 video1.mp4 #EXTINF:240,video2 video2.mp4 #EXTINF:72,video3 video3.mp4 #EXTINF:139,video4 video4.mp4 #EXTINF:192,video5 video5.mp4
The play list is on a HDD and is played on both a media player (WDTV) as well as a PC. I believe that I can set the WDTV to loop the video, but I'd prefer to include that command within the playlist so that it will work on both the WDTV and the computer.
Is this possible?
Results 1 to 9 of 9
No, m3u is too crude a format to directly support such features.
However, you could try the last line calling the m3u file itself as a cheat. Maybe it will work, maybe not.
Scott -
Perhaps an Avisynth script.....
Code:a=FFvideoSource("video1.mp4") b=FFvideoSource("video2.mp4") c=FFvideoSource("video3.mp4") d=FFvideoSource("video4.mp4") e=FFvideoSource("video5.mp4") Return(a+b+c+d+e).Loop(times=3, start=0)Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
An ASX/WVX metafile (but they're usually only supported on Windows machines). Probably a SMIL metafile, but with similar (Mac-centric) support restrictions.
Scott -
I just tried this and it didn't work. My media player (WDTV) only supports PLS, M3U & WPL playlist formats. I've Googled these types of playlists and "loop" or "repeat" and haven't found anything.
I'm assuming that none of these three playlist formats will allow a series of videos to loop.
Correct? -
I was assuming you were doing this on a computer. On a set top box media player like your (WDTV) I would look in the settings for looping. You may get lucky and have an option to loop videos in a folder.
Otherwise, you'll need to encode a long looping video.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Well, you could just as easily use an M3U format and list it explicitly like this:
for as long as you think it will need to loop. Doesn't use up any more space (unlike the re-encoding suggestion), easy to create, and is the equivalent of looping in most cases: how long do you really think it will need to loop anyway?Code:Source1.mp4 Source2.mp4 Source3.mp4 Source4.mp4 Source1.mp4 Source2.mp4 Source3.mp4 Source4.mp4 Source1.mp4 Source2.mp4 Source3.mp4 Source4.mp4 ...
Scott -
Yes. The WDTV has a setting that will allow me to loop the videos. However once set, it will loop (repeat) everything. I have playlists of videos, individual videos, photos and MP3s on the media player. I would like to loop some playlists but not others and none of the individual videos or MP3s. I'd prefer not to go into the settings menu and set it to repeat each time I want a playlist to loop. (I know that this is picky but it's a nuisance).
My default solution was to create a longer playlist like Cornucopia suggests but I was looking for a more elegant solution. However, it looks like that solution doesn't exist.
Anyway, thank-you everyone who has taken the time and effort to provide suggestions. Your help is very much appreciated.
Youtube playlist to M3U8 Playlist
By candita in forum Video Streaming DownloadingReplies: 2Last Post: 31st May 2017, 03:56 -
Reading AVCHD Playlist files BDMV\Playlist\*.mpl
By StrangeSolutions in forum Newbie / General discussionsReplies: 11Last Post: 10th Jun 2014, 23:23 -
rip a Youtube playlist
By AlanHK in forum Video Streaming DownloadingReplies: 6Last Post: 21st Feb 2014, 07:40 -
MPC-HC and YouTube Playlist
By iNfRaIiI in forum Newbie / General discussionsReplies: 5Last Post: 17th Dec 2013, 20:24 -
Potplayer playlist question
By rennes in forum Software PlayingReplies: 4Last Post: 1st Dec 2012, 01:03
