  1. Member Jijital's Avatar
    Oct 2011
    Rome, Italy
    Hello everyone,
    When authoring a BD with multiAVCHD, pop-up menu does not appear, when I press the remote key. And this is happening only when using 720p videos, because with 1080p, it pops-up fine!
    Of course, in the "Author" tab, the "Add pop-up menu" option is always checked.
    I thought it was my stand-alone player (Panasonic), but I also tested the disc on an LG BD player and I got the same failure.
    Any suggestion, please?
    Thank you,
    Jiji
    Windows 7 64b, Intel Core 2Quad Q9300 (2.50 GHz), 4GB RAM, 1TB HDD, ATI Radeon HD 4650
    It sounds like a multiavchd bug...but I doubt we will see any new version.
  3. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Have you tried making your menu in 1080p? I haven't used that s/w in a few years, but I don't recall having those issues........
  4. Member Jijital's Avatar
    Oct 2011
    Rome, Italy
    I don't think there is the option to set the menu to 1080p, or 720p, or at least, I could not find it.
    In any case, thank you Baldrick and Racer-x for your reply. It's not the end of the world, of course, just a little bit annoying.
  5. Member Jijital's Avatar
    Oct 2011
    Rome, Italy
    Problem solved!
    Actually, in the "Menu/Advanced" tab, the "Always match pop-up menu to the title resolution" option was not checked, in my settings. Checking that, just solved the issue.
    Thanks very much indeed!
    Jiji
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Thanks for posting the solution!
  7. Member Jijital's Avatar
    Oct 2011
    Rome, Italy
    That is the very least I can do. I do not post very much in here, but you guys have always been a great "help" to me and everybody.
    You ROCK!
