Hi, I have downloaded a movie in mp4 format and it resides on my HD and plays correctly from here. I copied it onto a friend's brand new 32GB USB stick and it will not play from the stick (either on my computer or on my Smart TV). Other mp4 videos play from this stick both on the computer and on the Smart TV. I then copied it onto another 32GB stick and it plays from there without a problem. Both sticks are formatted in FAT32. Both sticks are the same brand, just different models. Can someone give me an idea how to resolve this? Why would some play and others not?
Results 1 to 11 of 11
Did you friend get the stick from ebay at half the price you paid for yours?
http://www.zyra.net/fakestix.htm -
The one I am having issues with is a Lexar® JumpDrive® V10 USB flash drive and I know it is USB 2.0 since it was still in the package when I got it from my friend. The other one is a Lexar™ 32GB TwistTurn USB Flash Drive - I do not know if it is USB 2.0 or 3.0, but I think it is 2.0
And no it was not purchased on eBay, but from a reputable store.
Is the stick FULL?.....Did all of the files fit?
FAT32?....I thought FAT32 had a maximum file size of 1GB?
Just throwing it out there....I've been wrong before.
Yes it fit... with at least half the storage left if not more... and yes it is FAT32. Both sticks are.
So try format to NTFS or ExFat
maybe its perform better -
Not at all sure why this has solved the problem. I re-downloaded the video and it works just fine now. The original download worked on the other stick, but not this new one... Thanks everyone for your suggestions!
USB Video playback format hslp
By efiste2 in forum Newbie / General discussionsReplies: 4Last Post: 23rd May 2015, 19:08 -
Samsung Smart TV USB playback software
By Czarsvk in forum Software PlayingReplies: 2Last Post: 6th Aug 2014, 13:53 -
LG HDTV 42LM3450 MP4 USB playback issues.
By Sunshine Superman in forum DVB / IPTVReplies: 6Last Post: 11th Sep 2013, 13:57 -
VirtualDubMod and PotPlayer: what key to stop playback?
By falco2000 in forum Newbie / General discussionsReplies: 11Last Post: 17th Jan 2013, 16:23 -
USB Playback Woes
By phm14 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 28th Jan 2011, 22:23
