I have a Sky STB (Amstrad DRX890W) and would like to capture 5.1 audio via the HDMI. At the moment I can capture video and audio but that is just in AC3 2.0 using either Avermedia Capture HD or BlackMagic Shuttle.
If you can force the STB to output 5.1 to the Blackmagic, most or all of their capture devices can capture bitstreams into the 2-channel WAV track which BeSplit can then manually turn into a 5.1 AC3 file. If you do successfully capture the bitstream, it will sound like a lot of extremely loud, annoying noise before it's processed. Don't try playing it with the sound up.
I'm not sure whether you meant Intensity Shuttle or HyperDeck Shuttle, but both can capture 8-channel LPCM, so technically you could capture without post-processing if your STB supported multi-channel PCM output. It almost definitely doesn't though, especially since you're currently getting 2-channel.
The filesizes that way would be enormous, with no benefit to quality.
The alternative is a capture device from another manufacturer, like Hauppauge.
Hauppauge Capture with Colossus 2 and STB - Audio Loss
By jcmccorm in forum Capturing and VCRReplies: 6Last Post: 15th Nov 2015, 13:35 -
Best way to capture satellite/cable input from STB and stream RTMP out
By juguar in forum Video Streaming DownloadingReplies: 3Last Post: 21st Aug 2014, 02:40 -
Capture Video/Audio from STB (DVB) with SCART in W7MCE through USB (EzCAP?)
By DIRKZELF in forum Capturing and VCRReplies: 7Last Post: 16th Jan 2012, 19:10 -
mkv,vob audio can not play on stb
By afshin113 in forum AudioReplies: 3Last Post: 16th Jan 2012, 00:30 -
Home speaker recording (hardware needed)
By elmuz in forum AudioReplies: 0Last Post: 8th Sep 2011, 10:30
