Hello,
I have some MKV files that I want to burn to a Blu-Ray so they are playable on my Blu-Ray player. I use tsMuxer to convert the MKV to a Blu-Ray ISO and then burn the ISO to a Blu-Ray disc, and then everything works. However, for one of the MKV files, it refuses to work. I can play the video fine as an MKV, but once I convert it to the Blu-Ray ISO, nothing will open it on my computer, and if I burn it to a disc, my Blu-Ray player will not play it. The only thing that is able to open the resulting ISO is PowerDVD, and even then, the video is a little stretched. Every other MKV file works fine except for this one.
Any ideas?
Thanks.
Results 1 to 30 of 35
probably a non compliant file. re-encode it using uncropMKV or bd-rebuilder, this should fix it.
if uncropmkv crash, there is something wrong with your file. Bd-rebuilder will fail too , they both use X264.
BD Rebuilder is processing right now. Like I said, for some reason, PowerDVD is capable of opening the ISO, but nothing else is. The MKV plays fine in VLC or in any other program, even on the Blu-Ray player itself. Some BR players will not read MKVs so I have to do it this way. Every other MKV has no problem converting to ISO, then to disc and playing. Just this one.
Do you know of a better way to convert the MKV to a Blu-Ray than what I am doing that will make it work? Like I said, as an MKV, it plays perfectly/is not corrupt. Only when I go to make it a Blu-Ray is there a problem.
Originally Posted by Guphanti
Please do not use topic subjects like Help me!!! or Problems."
source: https://forum.videohelp.com/threads/72386-Forum-rules-Acceptable-Use-Policy-(AUP)
Originally Posted by Guphanti -
And I will add:
Your current title "What is wrong?" is a wrong approach to solving your problem as well.
But I'll also tell you what is wrong.
Originally Posted by El Heggunte
Fortunately some programs can do it for you without you having to mess with this.
But what is also "wrong" in this forum is coming in here and asking how to make an MKV you've likely "acquired" somewhere, to play on a blu-ray player. Don't expect much help with this.
Originally Posted by GuphantiI hate VHS. I always did. -
Guphanti, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Try to choose a subject that describes your topic.
Moderator redwudz -
The video is "All-22" film of high school football games. If you do not know what All-22 is it's basically wide angle footage taken from atop the bleachers to film all 22 players on the field for the purposes of practicing. It takes up too much space on the computers and we want to be able to have it on discs. It's HD and the total is too much for DVDs. We put chapters in an MKV to separate the games since just burning the raw footage does not work on all blu-Ray players and has no chapters to skip between games. That's why we need to burn the MKV.
in my opinion, Bd-rebuilder and tsmuxer are the best free tool for blurays.
When i want to create a bluray menu with trailer or intro video, i use Multiavchd ( way more complicated) . -
There's just too many comedians in Forums who pirate stuff, then whine about it not playing on their blu-ray players, and harass legit forums about it. Hence, some of us will respond in a certain way to garbage like that.
As per your problem, like I said, I believe it's the video streams in the MKVs that are not blu-ray compliant. Maybe the ones that "worked" are also not blu-ray compliant as well, but some players (out of no obligation) sometimes handle some Ok.
And, just because they worked in your blu-ray player, which may have a leniency on the spec, it does not mean they will work in another blu-ray player.
To ensure fluid compatibility you would need to encode under a compliant blu-ray profile. tsMuxeR is a nice tool, but it's only a muxer. It's not an encoder. All it really does is take streams, such as video and audio, and put them together in a structure - with no guarantee of compatibility.
Yes, encoding is lossy, but, with a good enough bitrate, or quality level, the damage would be very minimal for most sources.
I can suggest two things at this point. Try some of the tools mentioned and report back.
I also know MeGUI has blu-ray profiles as well - just encode with MeGUI, and mux with tsMuxeR after. (I know one person here who will say not to use MeGUI however. )
Or, you can download MediaInfo, and post the text info of what the MKVs actually contain, and we can direct you further.
(But, whatever you do - keep the MKVs separately if this is your Source/Master.)I hate VHS. I always did. -
Media info says resolution is 1920x800
1920x800 is not blu ray compliant. This is consistent with your non-complaint video height error message. Use the tools mentioned above to re-encode and author for BR disk.
I had a feeling that's what it was. Someone suggested a camcorder that records in 16:9. Does that mean anything? As for right now though, It's a really wide video on purpose as I described above. If I re-encode, will we lose parts of the picture, or is not something that you can notice? Also, which tool do I use to do this, since uncropmkv will not work due to the error above?
Thanks.Last edited by Guphanti; 12th Jan 2016 at 15:31.
Yup. Not blu-ray compliant. And I'm not just talking about the resolution mentioned only.
B-pyramid wrong, long GOPs, no delimiters or blu-ray compatibilty signalled, rate and buffer (vbv) way too high, too many b frames for profile 4.1, etc. I honestly can go on.
Some players may play it, but it's no guarantee. And if some work on some players, that doesn't mean they will work on all.
I know Johns0 hinted that there are methods, or fixes, that can be applied without re-encoding, and know about these, such as SPS, picture timing info, pulldown, levels, even fps and resolution, but honestly (no disrespect Johns0) I don't believe in these methods. They, IMO, are merely band-aid solutions, and can be very flaky. Only with a full (re-)encode, with a valid blu-ray profile, can you really acheive undisputed 100% blu-ray compatibility. But you can have something visually faithful to the Source with good settings, and you should keep your Source anyway, so it's not that bad.
You need to (re-)encode.I hate VHS. I always did. -
Handbrake won't make BR compliant streams. Try multiavchd as suggested above or a commercial product like DVD Architect or TMPGEnc Video Authoring works.
Okay I've got it loaded up in multiavchd, what is the process? From what I ascertain, I need to change 800 to 1080 in multiavchd, then hit "start" and it should make a file that works, right? At least that's what I have it doing now.
multiavchd finished and now it is time to burn to a disc. In the output folder there are 6 items (BDMV, Certificate, HDAVCTN (folder), details (text file), multiAVCHD (text file), and multiAVCHD.mpf.
Do I only burn BDMV and Certificate to a disc, or all the files? Do I make an ISO of the files and then burn that?
Thanks. -
I corrected the improper height in multiAVCHD, but now it says that the Ref count (5) is too high. How do I fix that?
Ref 5 isn't too high,it's the max allowed for authoring.Handbrake will make compliant files as long as you don't remove the black bars and keep the setting within parameters.
Pull! Bang! Darn!
Just got back and saw HandBrake was mentioned, so comment on it.
HandBrake will not produce streams that are blu-ray compliant. You can include all the right elements into HandBrake's "Advanced" tabs, but it will only output MP4/MKV, not something you can work with with blu-ray, like M2TS, or a BD structure, or even a raw stream to be properly muxed.
This is because much of the blu-ray compatibility is at the container level. Once a video stream, blu-ray compliant or not, goes through MP4/MKV in any remuxing, you broke compatibility.
HandBrake is still wonderful for lots of other stuff. And it would have been great for blu-ray output, BUT, until it - at the very least - can output raw streams, it will never acheive 100% blu-ray compatibility for its output.
Having said that, carry on. I personally would use x264 at the command line and properly mux as my method, but I think you're on your way here too.I hate VHS. I always did.
Can't FF or RW my burned Blu-ray disc
By MMathews in forum Authoring (Blu-ray)Replies: 5Last Post: 21st Jul 2015, 15:10 -
Cannot play burned blu-ray disc on my philips BDP2100
By RamiJ in forum Blu-ray RippingReplies: 3Last Post: 8th Jun 2015, 00:56 -
Blu-Ray Disc playback on computer
By dzachau in forum Newbie / General discussionsReplies: 1Last Post: 15th Jun 2014, 16:54 -
Burn mkv/whatever to blu ray disc playable on Vizio Blu ray player?
By Eric1987 in forum Authoring (Blu-ray)Replies: 3Last Post: 1st Dec 2012, 21:41 -
Blu-Ray burner wont recognize my Blu-Ray disc, Only DvD dics?
By PurkkaPoika in forum Authoring (Blu-ray)Replies: 5Last Post: 10th Jul 2012, 14:26
