Hi
So far, the only (easy) way I found to join spanned (4k) MP4 clips created with my Panasonic VX870 camcorder is using the provided HD Writer AE 5.2 software.
My problem today is that I could not find a way to join clips that were not imported (from the camcorder or SD card) using that software: I have two MP4 files from that cam that must be joined, but they were previously moved to another storage [without the accompanying files containing metadata, i.e. without the complete containing DCIM folder], so copying them back to a SD card doesn't work (HD Writer AE doesn't see these clips on the card without the missing metadata files) and I couldn't find a way to import these files back into HD Writer AE, in order to join them.
Any suggestion ?
				Results 1 to 10 of 10
	Have you tried join with mp4box? Or a frontend for mp4box like mymp4boxgui (under the join tab)? If they now can handle those mp4s.
	I haven't tried MP4Box yet...but for the record, Pegasys' TMPGEnc Smart Renderer 4, which is quite comprehensive and usually...smart, doesn't allow to encapsulate the resulting concatenated clip into a MP4 container because the source MP4 is "illegal"...Any other container allowed by TMSR4 for these clips (MPEG TS or MPEG PS) causes problems with my editing software.
	See if changing the audio settings in TMPGenc Smart Renderer will allow for mp4 output. Also, what editing software are you using that doesn't allow for ts or ps files?
	I am AMA-linking the MP4 files in Avid Media Composer 8.2; it uses QT as MP4 file reader and that's pretty restrictive Last edited by Benoit; 14th Jan 2016 at 05:05.
	Well, yes, the workflow is somewhat more complex: I need to join the files and use the resulting [single] long clip in a multicam (group) clip; also I am not working with DNxHR in a 4k project, but will do Frameflex pan&scan on this 4k AMA clip in a HD project: this means working with a proxy DNxHD res during the editing, but relinking to the original AMA source at a later time to get full res in the "zoomed in" clip before final render; in such a scenario, keeping the source MP4 files separate (joined on the timeline) is definitely possible but slightly more complex (time-consuming): need to create multiple group clips, etc.
	Got it. I've recently discovered that if I've got 3 or 4 breaks in one camera of a multicam show it's less time consuming to just make multiple groups. If you've got more than that it's a pain, I agree.
 The route I was using previously was to create my sync map in Avid and then AAF the track with gaps into Resolve and output as a single clip directly into a numbered Avid media folder.
 Glad you got it working.
  Panasonic Viera St50 series media viewer.. inabilty to play some MP4 filesBy idreos in forum DVB / IPTVReplies: 6Last Post: 8th Jan 2014, 23:52
  Joining x264 mp4 files issueBy dreamweaver888 in forum EditingReplies: 3Last Post: 27th Feb 2012, 19:30
  Mp4 or 3gpp Files merge/joining and decoding parserBy fidogenial in forum Video ConversionReplies: 0Last Post: 8th Dec 2011, 15:02
  Joining HD MOV files from camera & saving as mp4; "Invalid Audio Stream"By maskingtape in forum Newbie / General discussionsReplies: 30Last Post: 23rd Aug 2011, 13:30
  joining mp4 files but audio out of syncBy Liselotte in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2011, 22:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
