Is it possible to make subtitle *.ass to look like in the video? (I tried to make gif out of mp4 and it came out 4.88 Mb)
https://dl.dropboxusercontent.com/u/73038864/sample.mp4 (354Kb)
Video with hard sub, I want to do same with soft.
I see fade effect (fad tag), rescaling by Y axis (fscy tag) and blur, but tags "be" and "blur" can only blur border and not text themself. Placing 2 layers of text, one with border, another witout and blurring them doesn't look any like in sample.
Any other options? or is it impossible with *.ass?
	According to http://docs.aegisub.org/3.2/ASS_Tags/ you should set the border of letters to 0 (/bord0) and then the blur disables the letters themselves. I havent had a chance to verify this but the above page does explain it this way.
 Be aware that some viewers/players do not honor all ass codes, interpret them incorrectly and work better with *. SSA subtitles than *.ASS subtitles.
	Thanks for reply, I'll try again with different parameters. I want both letters and border be blurred. And just now I thought about using shadow instead of border.
 I'm doing it to myself and my player interpret all fine. But to the future: what's the difference between *.ssa and *.ass? As far as I understand *.ass is improved version with several new tags than *.ssa.
	Well, if top layer will be with text, border and shadow set to 0, fade, scale by X or Y axis and blur and bottom layer with same text and effects, but with shadow not 0, it will be almost same...
	The difference between SSA and ASS is indeed more tags and altered meanings for some with ASS. This is why some players and viewers that were originally set to play ssa tags and never updated, balk at new tags or fail from the mere fact that the position of these tags are incorrect when they are decoded as the old ssa tags.
 I have found in some instances that ASS will not display at all but changing too SSA, they play fine.
  Converting HD-DVD subtitles To BLURAY subtitlesBy wulf109 in forum Blu-ray RippingReplies: 1Last Post: 7th Sep 2014, 07:15
  SubtitlesBy Novaluke in forum DVD RippingReplies: 6Last Post: 4th Apr 2014, 05:54
  Forced Subtitles --> In Between Bit <-- Full SubtitlesBy OzDrDj in forum SubtitleReplies: 0Last Post: 1st Jun 2012, 03:11
  ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitlesBy eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 09:22
  MKV with subtitles to MP4 with subtitlesBy Evertype in forum Video ConversionReplies: 10Last Post: 6th Feb 2011, 14:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
