I need to stabilize a vertical video and really need help. Any advice?
I assume I have to change the aspect ractio and than export than stabilize but I'm having trouble changing to aspect ratio of an existing video so it fits it perfectly![]()
Premiere's warp stabilzer is pretty decent. Start with the default and then tweak to taste.
As to changing aspect ratio, just add the clip to your chosen timeline, right click and choose scale to frame size. Again you can tweak to taste. You will lose a lot of vertical information if you're going from a vertical to horizontal aspect ratio.
I would highly recommend scaling and trimming before stabilizing. -
The issue is the person in the video filmed it like a vlog. So the videos very up close to there face. The video was exported horizontal so i have black bars so i cant scale it to frame since it already is . And if i did zoom in it would be an unflattering video being basically up to there nose. -
So at this point it's not a technical question but an artistic one. The best answer is going to depend on the actual specific footage.
MJPEG in Premiere Pro CS6 Has No Audio
By koberulz in forum Newbie / General discussionsReplies: 12Last Post: 9th Nov 2015, 05:20 -
Can Premiere Pro CS6 export at 18fps?
By Ikejohn in forum EditingReplies: 19Last Post: 25th Sep 2015, 06:55 -
Final Cut Pro X vs Adobe Premiere Pro CS6 for capturing/digitising DV
By danvideodiary in forum Capturing and VCRReplies: 11Last Post: 7th May 2014, 18:28 -
CS6 Premiere Pro - Warp Stabilizer- Does not work for me yet
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 20Last Post: 15th Aug 2013, 14:39 -
Laptop for Adobe Premiere Pro CS6
By Amira_S in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2012, 10:01
