Hello,
How do you remove an audio track 2 channel maybe interleaved from a dual track avi video?
The Handbreak didn't help.
I tried AVIMux and VirtualDubMod but no avail.
The "mediainfo" shows only one audio ID though..
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 38mn
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 90.3 MiB (13%)
Alignment : Aligned on interleaves
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 504 ms
Writing library : LAME3.98r
Encoding settings : -m s -V 4 -q 2 -lowpass 17 -b 128
Language : Νε ξοπεδελεν -
Never mind. I understand that the audio track is dubbed and it can't be changed. Sigh..
If you have a similar problem in the future a round about but very quick way of doing it without re-coding or losing quality is to put the avi file in a mkv container - use mkvmergegui and then you should be able to see the extra audio file, if there is one. Just untick it and save the file. Should only take minutes...
How do i remove an audio track from an AVI file?
By alih786 in forum AudioReplies: 51Last Post: 29th Nov 2016, 06:31 -
separating an audio track to remove certain sounds
By efiste2 in forum AudioReplies: 4Last Post: 6th Aug 2013, 03:24 -
How to remove one audio channel from a single audio track?
By helloguys in forum Newbie / General discussionsReplies: 2Last Post: 19th Mar 2013, 12:35 -
Need to remove ONE audio track
By OneHit in forum AudioReplies: 9Last Post: 2nd Jan 2013, 07:14 -
How to remove audio track?
By MAAG in forum AudioReplies: 13Last Post: 13th Jun 2012, 18:19
