  1. How can I change the mouse wheel up and down to move forwards or backwards a minute?
    Under Preferences->General->Mouse and Wheel Up and Down choose Customize: Do nothing and then select Playback->Jump to->1Min. Forward and 1Min. Backward
  3. I have multiple instances enabled but whenever i play multiple instances only audio comes from one (the first one opened), all instances video will be playing. The second will start playing audio once the first is closed/finished (even though its on repeat video/audio playback, the first will repeat the video but would be muted).
    In essence, any way to have audio from all multiple instances at the same time?
    Have you tried change Audio renderer and see if it makes any difference?
  5. Wow thanks! So I first had it on Audio renderer: Waveout Headset then I changed it to DirectSound:Speakers Headset and now it works! Thanks mate
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Great!
