Hi,
I'm looking for a software that can handle the new subtitle format (Timed Text Markup Language 2 (TTML2)).
More information on this format can be found here:
http://www.w3.org/Submission/ttml-ww-profiles/#bib-TTML2
and here:
http://www.w3.org/TR/ttaf1-dfxp/
This format is basically an XML file which is working similarly to idx file (i.e. contains the beginning and end time for each Image (PNG file) and the height and width.
The software I'm looking for is going to convert this XML file into equivalent XML file that is used for BDN Subtitles in order to dump it in BDSup2Sub and convert it to idx/sub subtitle format.
I tried Subtitle Edit, but it didn't work. This might be because the subtitle are PNG images.
Below is an the first few lines of the TTML file:
Any suggestions or help would be highly appreciated.Code:<?xml version="1.0" encoding="UTF-8" standalone="yes"?> <tt xmlns="http://www.w3.org/ns/ttml" xmlns:ns2="http://www.w3.org/ns/ttml#styling" xmlns:ns3="http://www.ayz.com/ns/ttml#metadata" xmlns:ns4="http://www.w3.org/ns/ttml#parameter" xml:lang="cr" ns4:timeBase="media" ns2:extent="1280px 720px"> <head> <metadata ns3:schemaVersion="0" ns3:packageId="1025" ns3:movieId="11180" ns3:uuid="fc5" ns3:textType="SUBS"/> </head> <body> <div ns2:extent="387px 102px" ns2:origin="446px 542px" begin="00:00:00.417" end="00:00:03.211"> <image src="1.png"/> </div> <div ns2:extent="415px 53px" ns2:origin="432px 595px" begin="00:00:03.295" end="00:00:05.255"> <image src="2.png"/> </div> . . . . <div ns2:extent="198px 56px" ns2:origin="541px 592px" begin="01:13:11.135" end="01:13:13.470"> <image src="1040.png"/> </div> </body> </tt>
You could try contact the developer of subtitle edit( http://www.nikse.dk/SubtitleEdit/ ) and see if he can add some kind of support. If it's not a too complex OCR to text conversion.
Hello, have you got an answer to your question yet?
I tried Subtitle edit but it didn't work.
How do I rip DVD subtitles to PNG, JPG, or BMP files?
By Videogamer555 in forum SubtitleReplies: 12Last Post: 25th Oct 2015, 00:11 -
Converting Subtitles (XML + PNG) to idx/sub
By MounaLafi in forum SubtitleReplies: 24Last Post: 18th Jul 2014, 01:47 -
Question about overlapping images in BDN XML+PNG
By sglitch in forum SubtitleReplies: 0Last Post: 9th May 2014, 14:59 -
BDN XML -> DoST format subtitle converter
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 30th Jun 2013, 20:56 -
Using AVISynth to overlay PNG subtitles?
By csdesigns in forum SubtitleReplies: 8Last Post: 3rd Feb 2012, 12:36
