When I cut a WMV file with TMPGEnc, encode it to XXX.mpg and try to burn it on a CD-R (WinOn CD), I get following message : "XXX.mpg has an invalid muxer rate (3203) and is not suitable for VCD."
Any suggestions ?
hi
when enconding in TMPGenc besure to select the MPG-1 VCD in the upper tab and remember that the *.mpg (mpg-1) must be 352x288 25fps (pal) or 352x240 29.97 fps (ntsc) at CBR 1150kbps and audio 224 kbps.
try the VCDeasy (1.0.9) to burn the *.mpg file to the cd (you could make chapters). itīs very easy.
2man
getting an error message "burn unsucessful. the pack queue is empty. Muxer
By Glenn VK in forum Newbie / General discussionsReplies: 4Last Post: 17th Apr 2011, 17:57 -
.m2v outputs from ffmpegX won't compile in DVD-SP 4 (internal muxer error)
By bbartley9 in forum ffmpegX general discussionReplies: 4Last Post: 21st Aug 2010, 03:57 -
HCenc "Invalid MPEG-2 Frame rate" error.
By Maikeru-sama in forum Video ConversionReplies: 24Last Post: 8th Jul 2008, 18:09 -
VirtualDub invalid handle error
By 2manytapes in forum DVD RippingReplies: 0Last Post: 17th Mar 2008, 12:37 -
Getting error: Could not initialize encoder. Probably invalid input.
By chrishallowell in forum AudioReplies: 0Last Post: 1st Nov 2007, 23:29
