So...I've been streaming from my PC to TV for a while now. My TV is connected to our wireless network. I've been doing it directly to the TV, and most of the time it's good. But, the folder structure is cumbersome. You select the PC from the network, then Videos, then Folders, then...etc, etc. And they are only organized alphabetically.
The other way I can do it is using our XBox and Windows Media Centre. Works well, but the movies are only organized alphabetically by title.
I realize that I may not have things set up on my PC the best way...with regards to organization.
So...I'm looking for some advice to streamline either or both of the above.
OR....is there another way, like some software, that I can stream to my TV. I realize that having a Media PC or better Media Extender is best.
Would love some advice.
Results 1 to 13 of 13
Maybe Plex would make streaming easier. The Plex server would run on the PC, and Plex client app on the TV. (Plex now has an app for Tizen Smart TVs as well as some older models.) However, WTV files will need to be converted to something else for best results. Plex can play them now, but has difficulty finding and organizing them properly. https://forums.plex.tv/discussion/comment/1096401/#Comment_1096401
Emby might be another option, but there is currently no app for Tizen. If you have a new Samsung TV, you would have to use something other than the TV as a client.
Note that I don't use Plex or Emby because I have an HTPC connected to my PC and don't do much streaming. -
Tizen is the OS for 2015 Samsung smart TVs. For Smart Hub see https://www.youtube.com/watch?v=dDXZRw9b1pQ
Gotcha...thanks! I found the app on the Smart Hub.
Here's an additional question: Will the Plex server download cover art and movie info for the videos I already have? I did not receive the art or info when I "acquired" the movies. I'm sure I'll find out once I install the server, but just thought I'd ask. -
Why not do the streaming from the PC? On your PC just right click the video file and select "Cast To" (Windows 10) or Play To (Windows 8) and select the TV you want to cast to.
They won't be visible to everyone on the Internet, only to you. According to the page for the Plex Web App: "Communication happens between the browser and Plex Media Server (your PC) directly. In order to be able to access and manage your content when away from home, you'll need to ensure that you've successfully enabled Remote Access."
[Edit]I added "(your PC)" to the quote.Last edited by usually_quiet; 11th Jan 2016 at 23:14.
Well, it looks like it's running fine now. Perhaps it helped that I rebooted my PC. This is a great app.
Thanks!
Samsung Smart TV audio improvement to external speakers
By guatelize in forum AudioReplies: 15Last Post: 24th Apr 2019, 13:21 -
H264 MP4 too contrasty for Samsung Smart TV
By njitgrad in forum Video ConversionReplies: 13Last Post: 21st Jan 2015, 11:34 -
Browsing Network With Samsung Smart TV Probelms...
By justinfromcanada in forum DVB / IPTVReplies: 0Last Post: 8th Oct 2014, 16:27 -
Samsung Smart TV USB playback software
By Czarsvk in forum Software PlayingReplies: 2Last Post: 6th Aug 2014, 13:53 -
Streaming Blu-ray disc from PC to Samsung Smart TV - possible?
By CompVid in forum Media Center PC / MediaCentersReplies: 0Last Post: 24th Feb 2013, 06:37
