hi,
i use the mkvextractgui to extract subtitles stream from a mkv file created with makemkv. makemkv is omitting all the audio und subtitle stream that i don't need. to convert the sup-subtitles with bdsup2sub i have to extract them. how can i automatrically extract all subtitle stream, independently how much subtitles there are in the mkv? just demux ALL without to specify the sub manually.
i've found a script, but it's for linux and i use windows 7.
valit
the tool should have a command line, but when i try "mkvcleaver" only the gui opens.
i've tried to extract stream with the gui, before i've located the folder where mkvmerge.exe and mkvextract.exe are saved in (i use mkvtoolnix as portable software, it not "really" installed). but it doesn't extract anything. there is the message:
whats wrong?could not get any information from mkvmerge.exe
download and install the latest version of mkvtoolnix
valit -
Follow the message given to you.
To extract subtitles and other streams from MKV's I use gMKVExtractGUI.exe at least the extracted subtitle file is in srt or whatever rather than mks format.
Extract audio from mkv
By tun.tin in forum AudioReplies: 4Last Post: 17th May 2015, 18:07 -
I cant extract the whole subtitles from an mkv
By ErdeZGZ in forum SubtitleReplies: 18Last Post: 13th Aug 2014, 18:11 -
How do i extract .ass subtitles from an MKV file?
By ZEROthefirst in forum SubtitleReplies: 5Last Post: 14th May 2012, 16:31 -
MKVExtract won't extract subtitles from my .MKV file
By pepperjinks in forum SubtitleReplies: 12Last Post: 14th Mar 2012, 21:16 -
How to extract subtitles from MKV videos to convert them to AVI
By zikegi in forum Video ConversionReplies: 0Last Post: 15th Sep 2011, 21:47
