Hi everyone.
I'm converting video by MegUi for Youtube, using an AVI source with avisynth and audio is converted with Nero AAC. What happens is that after the conversion audio track is in sync but at the end of the clip, less then a second left, there's a clicking sound and the last part of the audio just before the click repeats itself again. I have no idea what is causing this. I'll add a clip for you to see/hear. Any ideas?
1. No problem with the source. It happens with every source. The source is frameserved from Vegas as AVI.
2. Audio is not filtered through the script. Audio is directly taken from AVI then sent to Nero AAC while bypassing the script and later muxed back to the video.
3. ffaudiosource is recommended for AAC and that is what I use.
Btw. zero latency is on, although even when switching it off the same error appears.
DTS to aac error with megui
By kkiller23 in forum AudioReplies: 6Last Post: 20th Jun 2012, 22:05 -
Process exits with error code, Indexing error: Audio decoding error (MeGUI)
By JokerX in forum Video ConversionReplies: 7Last Post: 18th May 2012, 18:18 -
Audio encoding error with MeGui
By [ss]vegeta in forum AudioReplies: 3Last Post: 23rd Oct 2011, 15:51 -
MeGUI Encoding Error - Pretty sure it's from the Nero AAC
By therealDr.Nick in forum DVD RippingReplies: 9Last Post: 3rd Aug 2011, 19:58 -
megui convert video how to keep orginal aac audio
By jamespoo in forum DVB / IPTVReplies: 0Last Post: 24th Jun 2011, 23:11
