Previously when using the LGP and RECentral (current version) I've had it set up to record mic audio into a separate MP3 track for easier editing. Up until a few days ago, everything was working perfectly fine... the MP3 files were approximately the same length as the video files, give or take a second or two. It was easy to sync up during editing.
However now, for some reason unknown to me, the MP3 files have been getting corrupt. This makes the MP3s shorter than the video by anywhere between 10-30 seconds, meaning that as the video progresses, the commentary becomes more and more of sync. Listening to the commentary, I can tell that it's corrupt due some sections getting garbled, or several words getting cut off between sentences. For instance, if I say.
"This MP3 will become corrupt and unusable" ...it'll turn out like...
"This MP.. come corrup.. sable" ...basically, words are cut out throughout the recording, thus making it shorter.
I do not know why the MP3 files are getting like this, it doesn't do it to EVERY recording, but it's enough that I end up having to ditch the commentary and upload videos to YouTube without.
Anyone know why this is happening? Nothing has changed with my laptop, it's a clean install of Win 7 x64 a few weeks ago and never did it before that.
Results 1 to 1 of 1
[AVerMedia News] Avermedia RECentral HDCP Protect Remove!!!
By Cauptain in forum Capturing and VCRReplies: 235Last Post: 3rd Apr 2026, 23:35 -
AVerMedia RECentral and separate MP3 files...
By PureChaosX in forum Capturing and VCRReplies: 1Last Post: 9th Mar 2016, 16:57 -
Yes I am recording HDMI HDCP over Avermedia LGP Lite Capture- simple
By BobbyGee in forum Capturing and VCRReplies: 8Last Post: 19th Sep 2014, 06:54 -
AverMedia LGP Capture Card Problem
By OutaTime27 in forum Capturing and VCRReplies: 2Last Post: 24th Aug 2014, 10:31 -
Avermedia LGP Question
By Jiehfeng in forum Capturing and VCRReplies: 0Last Post: 7th Apr 2014, 00:53
