    Jan 2016
    Kuala Lumpur
    So I my local video provider do allow us to download the video to be played later, and I managed to find the file. However it is in .MLV file, and I've tried almost all converter that I have in my computer, and none work to convert it to known container.
    Here is the media details:
    General
    Complete name               : C:\Users\Kuro Syamito\Desktop\Movies2072.mlv
    Format                      : MPEG-4
    Format profile              : Base Media
    Codec ID                    : isom
    File size                   : 180 MiB
    Duration                    : 25mn 48s
    Overall bit rate            : 973 Kbps
    Writing application         : Lavf56.7.104
    Video
    Format                      : AVC
    Format/Info                 : Advanced Video Codec
    Format profile              : High@L3.1
    Format settings, CABAC      : Yes
    Format settings, ReFrames   : 5 frames
    Codec ID                    : encv / avc1 / mp4a
    Duration                    : 25mn 48s
    Bit rate                    : 933 Kbps
    Width                       : 1 024 pixels
    Height                      : 576 pixels
    Display aspect ratio        : 16:9
    Frame rate mode             : Constant
    Frame rate                  : 25.000 fps
    Color space                 : YUV
    Chroma subsampling          : 4:2:0
    Bit depth                   : 8 bits
    Scan type                   : Progressive
    Bits/(Pixel*Frame)          : 0.063
    Stream size                 : 172 MiB (96%)
    Encryption                  : Encrypted
    Audio
    Format                      : AAC
    Format/Info                 : Advanced Audio Codec
    Format profile              : HE-AACv2 / HE-AAC / LC
    Codec ID                    : 40
    Duration                    : 25mn 48s
    Duration_LastFrame          : 151ms
    Bit rate mode               : Constant
    Bit rate                    : 34.9 Kbps
    Nominal bit rate            : 32.0 Kbps
    Channel(s)                  : 2 channels / 1 channel / 1 channel
    Channel positions           : Front: L R / Front: C / Front: C
    Sampling rate               : 44.1 KHz / 44.1 KHz / 22.05 KHz
    Compression mode            : Lossy
    Stream size                 : 6.45 MiB (4%)
    any help regarding this would be great!
  2. Member bat999's Avatar
    Feb 2008
    That's a clue.
