  1. Hi all,
    I need some help in understanding why my video encoded to mkv is sometimes stuttering during playback. The stuttering is most prominent during small movements, so my first thought was that QTGMC setting was too forgiving (using 'Slower'). Thus I encoded a segment of the file in three different speeds: 'Slower', 'Very Slow' and 'Placebo'. The resulting encodings are attached. The stuttering can be noticed between 8 and 11 seconds into the video, while the cars are moving. The whole video playback appears not to be smooth.
    However, I am unable to see any noticable difference regarding the stuttering between the three QTGMC settings above. Currently, I am suspecting that there is an issue with the indexer I am using (DGDecodeNV), but I am far from sure.
    I've also attached the sample AVS script used to encode the three sample files attached. Are there any obvious issues with it, or any improvement suggestions?
    Thank you in advance.
    Kind Regards,
    Veroslav
    Input AVC file:
    Original input file:
    General
    Complete name                            : C:\file.ts
    Format                                   : MPEG-TS
    File size                                : 4.05 GiB
    Duration                                 : 1h 57mn
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 4 927 Kbps
    Video
    Menu ID                                  : 30001 (0x7531)
    Format profile                           : High@L4
    Format settings, ReFrames                : 4 frames
    Codec ID                                 : 27
    Duration                                 : 1h 57mn
    Bit rate                                 : 4 296 Kbps
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Frame rate                               : 25.000 fps
    Scan type                                : MBAFF
    Scan type, store method                  : Separated fields
    Scan order                               : Top Field First
    Bits/(Pixel*Frame)                       : 0.083
    Stream size                              : 3.53 GiB (87%)
    Color range                              : Limited
    Color primaries                          : BT.709
    Transfer characteristics                 : BT.709
    Matrix coefficients                      : BT.709
    Audio #1
    Format                                   : MPEG Audio
    Format version                           : Version 1
    Format profile                           : Layer 2
    Codec ID                                 : 4
    Duration                                 : 1h 57mn
    Bit rate mode                            : Constant
    Bit rate                                 : 192 Kbps
    Sampling rate                            : 48.0 KHz
    Delay relative to video                  : 20ms
    Stream size                              : 162 MiB (4%)
    Language                                 : Spanish
    Language, more info                      : Clean effects
    Audio #2
    Format                                   : MPEG Audio
    Codec ID                                 : 4
    Duration                                 : 1h 57mn
    Bit rate                                 : 192 Kbps
    Delay relative to video                  : 44ms
    Language                                 : qaa
    AVS script:
    # Set DAR in encoder to 64 : 45. The following line is for automatic signalling
    global MeGUI_darx = 64
    global MeGUI_dary = 45
    LoadPlugin("C:\megui\tools\dgindexnv\DGDecodeNV.dll")
    LoadPlugin("C:\megui\tools\avisynth_plugin\UnDot.dll")
    ms = DGSource("C:\file.dgi",fieldop=0)
    ms = ms.Trim(8293,8793)
    ms = ms.crop(286, 26, -282, -6)
    ms = ms.Undot()
    ms = ms.Spline36Resize(960,ms.height)
    ms = QTGMC(ms, Preset="Placebo", Sharpness=0.8)
    ms = ms.Spline36Resize(ms.width,720)
    return ms
    x264 command line:
    C:\megui\tools\x264\x264.exe --level 4.1 --preset veryslow --cabac --ref 5 --deblock -3:-3 --partitions all --me umh --subme 8 --psy-rd 1.00:0.00 --merange 24 --trellis 2 --8x8dct --cqm flat --deadzone-inter 21 --deadzone-intra 11 --chroma-qp-offset 0 --threads 12 --lookahead-threads 2 --no-dct-decimate --bframes 6 --b-pyramid normal --b-adapt 2 --b-bias 0 --direct auto --weightp 2 --keyint 500 --min-keyint 50 --scenecut 40 --rc-lookahead 40 --crf 20.0 --qcomp 0.60 --qpmin 10 --qpmax 51 --qpstep 4 --stitchable --ipratio 1.40 --aq-mode 1 --aq-strength 1.00 --sar 16:15 --output C:\output.264 C:\script.avs
  2. I only downloaded the "slower" video but I don't see any problems here. 50 fps video does judder a bit on a 60 Hz monitor. However, changing the frame rate to 60 fps showed perfectly smooth video. Stepping through the video frame by frame there are a few places where one car moves but another doesn't. But I doubt that's QTGMC's problem. It's more likely motion artifacts in the original video or the final encoding.
  3. Thank you for your reply, jagabo.
    I am playing the video on my media player at 50 fps (an option I set in the player). I admit that it can be hard to notice the stuttering. I would also like to know whether I need to use AssumeTFF(), as the clip is "Top Field First", according to the media info?
  4. I haven't used DgDecodeNV but Donald Graft's MPEG 2 decoder (Mpeg2Source) sets AviSynth's field order. So I would guess DgDecodeNV does too. If the field order was backward you would see very obvious two-steps-forward-one-step-back motion. That's not the problem here.
    Try using a simple Bob() instead of QTGMC() and see if the motion looks any smoother.
  5. Thank you for helping me jagabo, much appreciated!
    Just tried with:
    Yadif(clip, Mode=1, Order=1)
    but no difference
  6. Actually, looking a bit closer, it appears to me that it is not the motion specifically that is stuttering, but the whole picture itself.
  7. In addition to the helicopter motion the camera might be panning with a little jerkiness.
