My HD PVR died and I bought a new HD PVR 2. I was recording previously with the bundled ArcSoft software and now with Capture.
I'm recording 720p movies. Previously the bitrate was set to 7mbps, but the movies were typically 3Mbps to 4Mbps, depending on content, and the quality was good. With Capture when I set 7Mbps I get 7Mbps, and when I set 3Mbps I get terrible quality and skipped frames. So with the HD PVR 2 I'm using about twice as much disk space as previously.
Is there anything I can do to get the same compression performance I got before?
No, HD-PVR 2 uses different encoding chip. I think first PVR compressed better, it didn't try to reach exact average bitrate you set if the movie is not difficult to compress which means final bitrate could be well below value you chose (In VBR mode of course). With HD-PVR 2 my experience is that whatever the content, it will always try to reach bitrate you set, even if the content is very easy. Encoder in PVR 1 is probably little better.
Thanks for the reply. I feel rather screwed. Bought a newer version, thought it would be better, and it's worse in one major way.
Is there any way to re-encode the captures in a way that will get me similar quality / bitrate to what the HD PVR gave? -
Are you using constant or variable bitrate with the PVR2?
Pull! Bang! Darn! -
After playing with FFMPEG I settled on recording 1080i video instead of 720p (it's from a settop box) and then using '-deinterlace -preset faster -crf 23'. The result is a 25fps movie with a bitrate 3-4Mbps that looks quite good. Conversion rate is 16fps, but because the movie is 25fps it's not that terrible.
How does bit rate effect video and slide quality?
By johnharlin in forum Video ConversionReplies: 1Last Post: 31st Dec 2015, 20:29 -
Bit Depth,Sampling Rate used for Uncompressed Audio-Bit Rate for Compressed
By alexander121 in forum AudioReplies: 9Last Post: 4th Apr 2015, 11:30 -
Capture Quality with Hauppage HD PVR
By imdanwhou in forum Capturing and VCRReplies: 4Last Post: 16th Dec 2012, 20:48 -
Overall Bit Rate, Bit Rate with Respect to Quality and Filesize
By kingaddi in forum DVD RippingReplies: 113Last Post: 17th Sep 2012, 22:56 -
what PVR win 7 (64 bit) software to use with this USB TV stick
By perfection in forum Capturing and VCRReplies: 6Last Post: 24th Nov 2011, 23:58
