I thought after rendering the sound would be synced with the rest but it isn't, there's an huge delay happening. How do I guarantee all of my sounds play at exactly the same time they should I play? I hope it's only the Pitch Shift effect doing this as I only used it on a channel, but im now paranoid if other effects do this too but more subtly. I use a couple of sounds sometimes layered on top of each other so they need all to play in sync to be snappy. Please help.
Are you checking the "Preserve Duration" option in the effect settings?
Fixing white balance shift shift
By yardline in forum EditingReplies: 6Last Post: 11th Mar 2014, 15:51 -
flaming ball effect in Vegas...
By sterankin in forum EditingReplies: 4Last Post: 21st Oct 2013, 10:16 -
Solved:possible to automatically correct audio pitch and sync it with video
By Srivas in forum EditingReplies: 2Last Post: 4th Jul 2013, 13:49 -
Avidemux audio sync problems (shift doesn't fix it!!)
By awi1991 in forum Video ConversionReplies: 13Last Post: 20th Feb 2013, 11:49 -
Sony Vegas how to make this effect?
By wingfan in forum EditingReplies: 0Last Post: 16th Jun 2011, 11:53
