My DVD player just came in today and I typed in the codes to make it region-free. Everything seemed to work great until my tray wouldn't open. I tried unplugging it, plugging it back in, and pressing eject: didn't work. I tried holding the power button on the remote paired with each button on the player: didn't work. The display says open, then close, then load, then goes back to open and stays there. I'm at a loss for what to do now. Any suggestions?
Results 1 to 10 of 10
according to the user manual of the samsung e360 :
There is a procedure on page 13 to revert to factory settings. Remove any disc and press the play pause button on the box for more than 5 seconds. I do not know how safe it is to do that though. So use at your own risks or wait for someone else to chime in.Last edited by ackboo; 6th Jan 2016 at 17:08.
try these steps
dealer lock linkLast edited by ackboo; 6th Jan 2016 at 17:26.
there are some hints in this thread, does it look like what you did?
https://www.videohelp.com/dvdhacks/samsung-dvd-e360/11880 -
Can you post what you did to fix your issue so others can read and benefit from it.
Tray Error on samsung dvd-E360
By gabotronia in forum DVD & Blu-ray PlayersReplies: 6Last Post: 30th Apr 2015, 14:15 -
Samsung E360 DVD USB video playback autoplay autorepeat??
By nerys in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Mar 2015, 11:19 -
Samsung DVD P185
By alltime in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Jun 2012, 12:03 -
Samsung DVD-HR756
By walidon in forum DVD & Blu-ray PlayersReplies: 6Last Post: 25th Apr 2012, 06:06 -
Samsung HT-C450/XEU & Samsung BD-C5300 hacks/codes needed
By raindancerob in forum DVD & Blu-ray PlayersReplies: 8Last Post: 5th Mar 2011, 11:45
thank you!!!
