Something is making the gods align so I don't finish this project but it will not give up. Anyway, right when I was about to finish, the track motion decides to stop showing up. I see it spawning outside of the monitor near the windows status bar down there, but I can't click on it because it's outside, it's really annoying. I tried with default layout, even changing resolution, but the window doesn't appear. Please help.
Ok, I just figured a way to do this... I had to enable "hide the task bar" in windows options and it was lying under there, then I moved it back.
Assuming you are using Win7:
Click the icon in the taskbar to ensure that the program has focus. Then hold down the Windows key and press the right-arrow a few times. That should move the window across your screens and eventually bring it back onto the screen that is still active.Google is your Friend
Sony Vegas - Scripting - Adding track motion preset
By samsam in forum EditingReplies: 1Last Post: 7th Oct 2020, 00:52 -
Sony Vegas Automated track volume based off separate track?
By Mitalis in forum EditingReplies: 5Last Post: 18th Nov 2012, 17:51 -
Sony Vegas render template for clip on PC monitor
By mltwitz in forum Authoring (DVD)Replies: 2Last Post: 23rd Aug 2011, 14:17 -
Sony Vegas - Track Motion presets file location?
By sdsumike619 in forum EditingReplies: 2Last Post: 13th Jun 2011, 10:34 -
Need help with setting borders for track motion in Vegas Studio
By gtmb in forum EditingReplies: 1Last Post: 20th May 2011, 15:48
