Hello.
I have a PAL TFF 1080i mpeg2 TV capture .mpg source and wish to convert it to 576i (yes "i" so as not to lose "motion fluidity") h.264/.mp4.
I also have similar sources from other TV channels as captured h.264/.mp4.
I have used avisynth for years to resize by deinterlacing/resizing/re-interlacing.
Is it possible to re-interlace natively in ffmpeg ?Code:# LAST is deinterlaced to double framerate using QTGMC ie incoming is 50fps progressive AssumeTFF() #choose the SAME field order like before deinterlacing Blur(0,0.5).SeparateFields().SelectEvery(4,0,3).Weave() #reinterlace PAL TFF from from PAL 576p50 assuming original source was TFF AssumeTFF() #choose the SAME field order like before deinterlacing AssumeFPS(25) >> "%avs1%"
So far I have this in the commandline to resize from PAL TFF 1080i into PAL 576p50, but of course it is now progressive:
Can some kind soul please indicate how to use ffmpeg commandline to reinterlace the PAL 576p50 into PAL TFF 576i25.Code:"%ffmpegexex64%" -loglevel error -i "%inputfile_1080i%" -map_metadata -1 -an -sws_flags lanczos -filter:v yadif=1:0:0,setdar=dar=16/9,scale=720:576,colormatrix=bt709:bt601,unsharp -r 50
Why can't you keep it at 50fps, as going to 25i will just cut the vertical information in half while doing nothing for "motion fluidity" compared to 50fps.
I'd thought of that too.
- media player handles 576i (not P50)
- TV handles 576i (not P50)
I could keep it as 1080i however the desired result of 576i .mp4 file is much smaller and retains "motion fluidity"
Thanks. I did some goggling and testing and there were a few more settings to set, since the re-interlacing step was also needed
This seems to do the trick, piping to x264 for encoding (some time ago I saw problems with ffmpeg interlaced h.264 encoding whereas x264 worked) :Code:"tinterlace=4:flags=vlpf" and ":interl=0:in_color_matrix=bt709:out_color_matrix=bt601"
Code:set PARF1fc=.\framecount.txt "C:\software\mediainfo\mediainfo.exe" --Inform=Video;%%FrameCount%% "%inputfile_1080i%" > "%PARF1fc%" FOR /F "usebackq tokens=1" %%G IN ( "%PARF1fc%" ) DO SET FRAMES=%%G DEL "%PARF1fc%" REM --frames "%FRAMES%" "%ffmpegexex64%" -loglevel error -i "%inputfile_1080i%" -map_metadata -1 -an -sws_flags lanczos+accurate_rnd+full_chroma_int+full_chroma_inp -filter:v yadif=1:0:0,setdar=dar=16/9,scale=720:576:interl=0:in_color_matrix=bt709:out_color_matrix=bt601,unsharp,tinterlace=4:flags=vlpf -r 25 -flags +ildct+ilme -ildctcmp satd -top 1 -f yuv4mpegpipe - | "%X264EXEx64%" - --stdin y4m --thread-input --threads 8 --frames "%FRAMES%" --preset slow --interlaced --tff --profile high --level 4.1 --no-cabac --crf 18 --sar 64:45 --colormatrix bt470bg -o "%PARtemph264%"
Albeit tinterlace is newer and recommended filter, older http://ffmpeg.org/ffmpeg-filters.html#interlace should work also:
vertical lowpass may give suboptimal results - you can disable it and give a chance to other approaches (at least i prefer sometimes to control how it is applied).Code:interlace=lowpass=0:scan=tff
Both - depends what is target for aliasing reduction but usually some tricks - it can be more refined trough http://avisynth.nl/index.php/External_filters#Anti-aliasing - vertical low pass filter implemented in ffmpeg is quite crude in terms how it reducing vertical resolution...
FFMPEG QUESTION :How do I take 10bit jpeg with FFMPEG?
By Jamaika in forum Video ConversionReplies: 10Last Post: 6th Jul 2015, 13:41 -
FFmpeg Runtime error / FFmpeg git-df82454 32-bit Static (2012-10-03)
By MashedPotatoes in forum Newbie / General discussionsReplies: 5Last Post: 6th Oct 2012, 17:22 -
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum Capturing and VCRReplies: 1Last Post: 14th Feb 2012, 04:11 -
Which ffmpeg options are used behind the scenes by ffmpeg?
By roberto.aloi in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2011, 05:09 -
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 12:04
