How can I tell if the video player in a streaming website uses real streaming or psuedo streaming?
Results 1 to 15 of 15
Just did a quick check on this and..
Pseudo streaming allows random seeking.
This is the biggest difference between the two.
Referencing:
1. flash.flowplayer.org/plugins/streaming/pseudostreaming.html
2. searchvirtualdesktop.techtarget.com/definition/Real-Time-Streaming-Protocol-RTSP
Hope this helped.Last edited by Shaylen; 5th Jan 2016 at 13:57.
So if the video has to load all the way before it plays, then that means it's real streaming?
But provided you loaded all of the file you can still seek random points right? In real streaming?
Is there a way to be 100% sure? -
Real time is fairly close if no different to live streaming.
I need an example to confirm this.
Can you get one? -
what are you talking about ?
sounds like gibberish
a Dl is a complete file, it means it buffered some place in your browser cache
streaming, is sent just ahead of display, streaming is often sent in segments
never heard of Pseudo streaming -
No such thing as psuedo streaming,any video needs to stream to play over the internet or just from your computer to a ps3 over a lan.
Pseudo-streaming is a referenced term.
https://en.wikipedia.org/wiki/Progressive_download -
Nothing to do with psuedo streaming,just downloading a video compared to a streaming video where as a downloading video can be viewed as streaming at a point.
http://cdnsun.com/knowledgebase/cdn-video/differences-between-true-streaming-and-pseudo-streaming
This is a site that tries to tell the difference but it still left me confused as to how can I tell which one is which from a viewer's standpoint. -
The site is favouring pseudo testing more so I too feel a little off.
I know there's that saying that one trusts what's on the internet and here's one perfect example that kinda forces us to adhere to what info's been displayed. I am doing a couple of searches and there's no direct response [like this].
More info is yet to surface about this issue and that's the conclusion I've come up with.
All sites referenced here are probably the best gathering of this than any.Last edited by Shaylen; 6th Jan 2016 at 19:04.
Some tips how a viewer can find out if it is pseudo or true streaming:
- look into player source code and look if there is a query string parameter defined (startparam, etc), if so then it is pseudo streaming.
- look into firebug network tab, if the stream is not HTTP (for example RTMP) then it is true streaming.
- look into firebug network tab and then seek the video to not yet downloaded part - if it is pseudo streaming then you will see on the network tab something like: http://pseudo-streaming-test.cdnXXX.com/blenders-big-buck-bunny.mp4?start=410, notice the ?start=410 (it is the seek request to the server) if you will not see anything like that then it is true streaming
The last tip is I belive an ultimate answer
CDNsun
Free media streaming server for live streaming
By sambir in forum Video Streaming DownloadingReplies: 1Last Post: 11th Mar 2015, 03:23 -
How do I find the "real" location of the streaming video?
By xtal_01 in forum Video Streaming DownloadingReplies: 8Last Post: 13th Oct 2014, 11:58 -
Need Windows streaming encoder for Quicktime/Darwin streaming server?
By The village idiot in forum Video Streaming DownloadingReplies: 0Last Post: 10th Feb 2012, 15:50 -
I want to make a streaming server for streaming into a PHP/HTML site
By cassiell2085 in forum Video Streaming DownloadingReplies: 0Last Post: 31st Jan 2012, 10:23 -
Create video file that allows pseudo streaming
By gffb in forum Video Streaming DownloadingReplies: 4Last Post: 22nd Jul 2011, 00:07
