How do I check the muxer settings? How do I know what the correct extension should be? You're talking to someone who knows nothing.One common issue is you have to enter the correct file extension in the final Save As dialog. It isn't filled in automatically, not correctly anyway.
Check the muxer settings just to be sure it's looking for "%(tempaudiofile)" and not something else.
>When you say the extension has to match the content, what do you mean by the content?
Just reminding people not to use .mp3 from my example, unless that's what the file really is.
Quoting myself from here,Here's the log with highlights added, and with the redundant progress messages removed. The name seems correct at the audio encoder, but completely different at the muxer:'Output filename' is the filename of the temporary file that the encoder creates. By default it will be %(outputname).audio or %(outputname).video, but it is recommended to change '.audio' and '.video' to the correct extension as some multiplexers rely on extensions for file type detection.Code:[*] Beginning dub operation. [i] Dub: Input (decompression) format is: YUV420. [i] Dub: Output (compression) format is: YUV420. [i] AudioEnc: qaac 2.47, CoreAudioToolbox 7.9.8.3 [i] AudioEnc: test.mp4.Audio.mp4 [i] AudioEnc: AAC-LC Encoder, TVBR q91, Quality 96 [i] AudioEnc: 0:00.960 (0.9x) [i] AudioEnc: 0:01.000 (0.9x) [i] AudioEnc: 48048/-1 samples processed in 0:01.078 [i] AudioEnc: Overall bitrate: 88.3316kbps [i] AudioEnc: Optimizing...done [i] Mux: AVC-H264 import - frame size 1432 x 1076 at 23.976 FPS [i] Mux: Importing AVC-H264: |==== | (20/100) [i] Mux: Importing AVC-H264: |=================== | (96/100) [i] Mux: Importing AVC-H264: |=================== | (98/100) [i] Mux: Importing AVC-H264: |=================== | (95/100) [i] Mux: [i] Mux: AVC Import results: 24 samples - Slices: 1 I 6 P 17 B - 1 SEI - 1 IDR [i] Mux: Stream uses forward prediction - stream CTS offset: 2 frames [i] Mux: [Importer] Unknown input file type for "test.mp4.m4a" [i] Mux: Error importing test.mp4.m4a: Requested URL is not valid or cannot be found [E] Error: CLI: The multiplexing process failed with error code 1 (00000001). Check the log for possible error messages.[*] Ending operation.
Results 31 to 42 of 42
Please read these tutorials and guides, they will really help.
How to use the external encoder feature, a brief overview (virtualdub.org) (the original guide, a bit hard to "get")
Using External Encoders In Virtualdub (virtualdub.org) (one of my early guides)
VirtualDub: save direct to MP4 with external encoders (encodingtalk.com) (another one of mine, very popular in its day)
VirtualDub External Encoder Tutorials (doom9.org) (pointers to more resources) -
Thank you, sneaker, but I'm quitting this experience.
It's not worth to download and install a 190 Mb file just to normalize an audio, what I already do using SoundForge, this way having much more control.
When I saw Staxrip doing this using only a single line, I thought it could be done with Vdub in the same way, but I got stuck in a maze.Thank you. -
Yes, raffriff42, the line is exactly the same.
"Anonynous pipe" error is related to CoreAudioToolbox.dll missing file, I guess.
When send log to a file, I get this message "Write error occurred on file: anonymous pipe" in a window and "ERROR: 193: CoreAudioToolbox.dll" in log file.Thank you. -
Qaac folder tree:
D:\programs\encoders\quaac\
| libgcc_s_sjlj-1.dll
| libsoxconvolver.dll
| libsoxr.dll
| libsoxrate.dll
| msvcp120.dll
| msvcr120.dll
| qaac.exe
| refalac.exe
\---QTfiles
....| ASL.dll
....| CoreAudioToolbox.dll
....| CoreFoundation.dll
....| icudt46.dll
....| icuin40.dll
....| icuuc40.dll
....| libdispatch.dll
....| libicuin.dll
....| libicuuc.dll
....| objc.dll
....| pthreadVC2.dll
....\---Microsoft.VC80.CRT
............Microsoft.VC80.CRT.manifest
............msvcp80.dll
............msvcr80.dllThank you. -
Unfortunately, I found no difference between results "with and without" normalized audio.
Both audios are almost the same... (!)
And --normalize argment has no extra parameters to set.
Any ideas?Thank you. -
How different audio will be after normalization depends on source, naturally. What kind of normalization do you want?
You are right. It depends on source.
Maybe, I said bullshit.
Sometimes, I get a video with a bad (high and low) levels on audio.
SoundForge give me the ability to change those levels using "Peak" or "Average RMS".
And sliders to test and see (actually, hear) results.
But it's OK.
I have now a new way to process video using qaac and I appreciate your guidance through External Encoders settings.
Thank you. -
CLI programs obviously won't provide any fancy sliders with preview.
I'm not sure what I would recommend to you so I'm gonna list some options for you to look at:
- qaac has more parameters than only --normalize: --gain, --drc, --limiter . See doc: https://github.com/nu774/qaac/wiki/Command-Line-Options
- VirtualDub has its own normalization/gain filters and also an option to view the audio with a diagram and preview. See VirtualDub help (F1) about "Audio volume", "Audio filters" and "Audio display".
- there's a popular ffmpeg filter called "dynaudnorm". Maybe you should read up on it: https://superuser.com/questions/323119/how-can-i-normalize-audio-using-ffmpeg
ffmpeg can be integrated as an external encoder (it has aac encoding though probably worse than qaac. Again: there might be batch tricks to combine both)
Virtualdub External Encoder feature.
By racer-x in forum Newbie / General discussionsReplies: 148Last Post: 13th Jul 2024, 19:13 -
External encoder in Virtualdub fails at multiplex
By sum_guy in forum Video ConversionReplies: 3Last Post: 28th Sep 2015, 16:48 -
how to use mencoder as external encoder of virtualdub?
By ntg029learner in forum Newbie / General discussionsReplies: 0Last Post: 6th Dec 2014, 23:37 -
Use Badaboom as an external encoder in Virtualdub
By kaskaï in forum Video ConversionReplies: 5Last Post: 21st Oct 2011, 13:38 -
External Drive Issues
By Squid_uk in forum ComputerReplies: 9Last Post: 18th Aug 2011, 04:52
