I have a .mp4 file h264 codec
H264 codec doesn't support on my Device
I there any way to Change H264 to MPEG4 Video
h264 is mpeg4 video. See https://en.wikipedia.org/wiki/MPEG-4
But maybe you want divx/xvid mpeg4 part2 video? Then must you reconvert with for example Xmedia Recode(use the dvd player profile for example, or change to xvid video or mpeg-4 under the video tab). -
General
Complete name : G:\2015 New Movies\file 1.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 658 MiB
Duration : 2h 20mn
Overall bit rate : 656 Kbps
Encoded date : UTC 2015-11-07 21:37:46
Tagged date : UTC 2015-11-07 21:37:46
gsst : 0
gstd : 8416931
gssd : BCAA6C185
gshh : r2---sn-fapo3ox25a-3uhe.googlevideo.com
Video
Format : AVC
Format profile : Baseline@L3.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : avc1
Duration : 2h 20mn
Bit rate : 557 Kbps
Maximum bit rate : 1 751 Kbps
Width : 640 pixels
Height : 360 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.097
Stream size : 559 MiB (85%)
Tagged date : UTC 2015-11-07 21:39:42
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 20mn
Bit rate mode : Variable
Bit rate : 96.0 Kbps
Maximum bit rate : 103 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 96.3 MiB (15%)
Title : IsoMedia File Produced by Google, 5-11-2011
Language : English
Encoded date : UTC 2015-11-07 21:38:59
Tagged date : UTC 2015-11-07 21:39:42 -
And this mp4 doesn't work on your device? (AVC=H264=mpeg4 part 10)
H264 video cutter with smart re-encoding (alternative to VideoRedo H264)
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jul 2014, 08:42 -
Encoding For Better Quality? Codec: H264 - MPEG-4 AVC (part 10) (H264)
By derek123 in forum Video ConversionReplies: 7Last Post: 20th Jan 2014, 04:01 -
encoding with x264 and h264 codec only use 30-50% cpu
By Slind in forum Video ConversionReplies: 32Last Post: 26th Nov 2013, 20:29 -
Expert advice needed regarding mpeg2 (ts) to mpeg4 (h264) encoding issue
By janvandenberg in forum Video Streaming DownloadingReplies: 16Last Post: 13th Dec 2011, 17:52 -
Re-encoding MP4 to change codec
By Joolz2020 in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jan 2011, 21:58
