Hi there!
Some 10 years ago I bought the Sony CCD-TR61E and used it for a while. The other day I found a bunch of the cassettes I filled - but can lo longer find the charger for the camera battery...
Any suggestions?
NB: At the time I also invested in a Canopus analog-digital converter box and an I/O card for my PC. I'll try to resume my transcribing to DVD at one stage, but first I need to see what's on the cassettes LOL
Cheers, and thanks for any help!
That camera uses np-55 batteries (double check.) Even if you can't find the direct connector, you should be able to find Sony or aftermarket chargers (and batteries) that will work.
Thanks for your reply, smrpix! The manual lists the battery as NP-F330 and calls it a Info-Lithium battery.
The charger is listed AC-L10A/L10B/L10C AC power adapter.
Will google for these or equivalents.
I figured at one stage that I may be able to adapt one of my myriad of chargers/power adapters if I can figure out the exact specs of the Info-Lithium battery and the USB connection to the camera that feeds it...
Cheers,
Luis
lost charger for Sony video Hi8 analog cam
By carioca(da_gema) in forum TestReplies: 2Last Post: 12th Feb 2016, 12:10 -
Video recorded from IP Cam - No audio unless I play back with IP Cam app
By momo123 in forum Software PlayingReplies: 5Last Post: 10th Aug 2015, 13:58 -
Audio Issues Sony MiniDV Tape w/Sony DCR-HC46 cam
By tarana in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 6th Aug 2015, 21:35 -
Strange Audio issue on Mobile Devices - Video taken with Sony HD Cam
By timothy001 in forum AudioReplies: 12Last Post: 6th Aug 2015, 11:38 -
I lost my cam corder files,need to recover them
By pierre- in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 13th Aug 2012, 11:29
