Hello!
My friend recorded a video with mp4 format but when we sit on computer found that there is no sound.
Here are the media-info logs:
I have tried VLC, MPC-HC latest version, mpv on Linux , no one can show any sound sign.Code:General Complete name : E:\20151220_020223.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom/3gp4) File size : 90.0 MiB Duration : 45s 35ms Overall bit rate : 16.8 Mbps Encoded date : UTC 2015-12-20 00:03:09 Tagged date : UTC 2015-12-20 00:03:09 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings, CABAC : Yes Format settings, ReFrames : 1 frame Format settings, GOP : M=1, N=30 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 44s 666ms Source duration : 44s 680ms Bit rate : 16.9 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Rotation : 90° Frame rate mode : Variable Frame rate : 29.812 fps Minimum frame rate : 5.009 fps Maximum frame rate : 30.060 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.273 Stream size : 90.0 MiB (100%) Source stream size : 90.0 MiB (100%) Title : VideoHandle Language : English Encoded date : UTC 2015-12-20 00:03:09 Tagged date : UTC 2015-12-20 00:03:09 Color range : Limited Color primaries : BT.601 NTSC Transfer characteristics : BT.601 Matrix coefficients : BT.601 mdhd_Duration : 44666 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 45s 35ms Bit rate mode : Constant Bit rate : 2 250 bps Nominal bit rate : 128 Kbps Channel(s) : 1 channel Channel positions : Front: C Sampling rate : 48.0 KHz Frame rate : 46.875 fps (1024 spf) Compression mode : Lossy Stream size : 12.4 KiB (0%) Title : SoundHandle Language : English Encoded date : UTC 2015-12-20 00:03:09 Tagged date : UTC 2015-12-20 00:03:09
I suspect that is recorded without audio, but I'm not entirely sure. I have no clue anymore, please any help.
Edit: tested on Windows 7 Ultimate / Linux Debian 8.2
Thanks in advance.
Happy new year
there is NO sound in the audio stream its blank
"Stream size : 12.4 KiB (0%)"
video
"Stream size : 90.0 MiB (100%)
Source stream size : 90.0 MiB (100%)"
he must have had recording volume off, or his fingers over the mic -
I doubt that he would have made any errors during registration, any of these you noted thee wizard. (bad for him, a record that gone in vain)
I will ask for confirmation, how the heck he recorded.
...Then here we can't do anything else.
Thank you very much for clarification.
Regards -
errors during 'registraion' ?
do you mean recording ?
media info shows 0% of the file as audio
but shows an audio format
to me that means it has a 'Blank' audio tract,
same thing as if you used a camcorder with out the mic plugged in
OR the record volume turned off
unless there is an operational defect in the phone
it was operated incorrectly -
Well, with "registration" i mean recording, sorry.
I haven't yet received a confirmation from the author but with the numerous possibility is that he recorded with volume turned off.
I suspect more of it.
Thanks once again, maybe I can confirm days later again.
Kind regards
Sound broken mp4
By correx in forum Software PlayingReplies: 8Last Post: 7th Oct 2014, 05:20 -
DVDFab No Sound when creating MP4. Change extension to M4V and sound works
By hackerjunk in forum DVD RippingReplies: 2Last Post: 5th Jun 2014, 16:04 -
5.1 Sound in MP4
By encodingmonkey in forum Video ConversionReplies: 0Last Post: 14th Aug 2013, 15:14 -
No sound when using Avisynth with x264/mp4
By MADestruction in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2012, 15:25 -
MP4 to avi No Sound
By PabloFX in forum ffmpegX general discussionReplies: 13Last Post: 5th Feb 2011, 08:06
