I want to include some video clips from a samsung phone on my home video. I got Wondershare for converting them but although they now load into Video studio 11, they dont play during the playback. just a black screen with sound? Any help appreciated
What format did you convert them to ? If you don't know use mediainfo (view=>text) . Does the converted video play in other applications like media players (e.g. MPCHC, VLC etc...) and only fail in video studio ?
If the conversion actually worked fine in other programs, perhaps the format and/or settings you used were incompatible with movie studio. In that case, you can try converting to a format this is actually supported -
" I got Wondershare for converting them "
what did you convert them into ? what format
and what orientation did you use when recording
did you hold the phone vertical or horizontal ?
vertical is not DVD compatible -
Thanks for your replies. I tried avi and mov they do play as individual clips in video studio but when i insert them in my timeline with other clips from my camera they dont play during the finished video , just a black screen and sound. I thought it might be a memory thing with my pc?
Thats all I have. I just tried converting to mp2 and that seems to work better
Please help: Audio from YouTube video works everywhere except from phones
By MrBadMan in forum Video Streaming DownloadingReplies: 9Last Post: 29th Apr 2015, 04:39 -
Blue tooth earpiece seems compatible with all phones
By jimdagys in forum Newbie / General discussionsReplies: 1Last Post: 23rd Apr 2013, 12:46 -
Is there a volume normalizer for mp3s for android phones?
By yoda313 in forum Off topicReplies: 4Last Post: 12th Oct 2012, 19:06 -
What mobile phones uses VFR (or CFR) for recorded video clips?
By Gew in forum Portable VideoReplies: 0Last Post: 27th Jan 2012, 12:49 -
How to ffmpeg to convert video to play in mobile phones.
By skillednerd in forum Video ConversionReplies: 6Last Post: 7th Apr 2011, 15:24
