Hello i have a problem with tsmuxer when converting either mkv files to ts or m2ts files to ts.
Well my problem is that when i playback my video from mkv with DTS sound the video and sound our not sync well and they get more and more out of sync with time until the video crash.
But when i convert the mkv to ts the dts plays fine but there is a problem with the video.Every few frames you can notice a small frame lag its like every last frame of 1 sec time the video lags for a very few time you can notice it very hard but its annoying i tried every settings or almost and still the lag is there.
Any solution?????please.
Thank you.
Closed Thread
Sure here is some info:General
Complete name : C:\Users\ole\Downloads\The.Martian.2015.1080p.BluR ay.AVC.DTS-HD.MA.7.1-RARBG\BDMV\STREAM\02175.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 35.5 GiB
Duration : 2h 21mn
Overall bit rate : 35.8 Mbps
Maximum Overall bit rate : 48.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : 27
Duration : 2h 21mn
Bit rate mode : Variable
Maximum bit rate : 34.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Audio #1
Menu ID : 1 (0x1)
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Muxing mode : Stream extension
Codec ID : 134
Duration : 2h 21mn
Bit rate : Unknown / 1 509 Kbps
Channel(s) : 8 channels / 6 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
But i Downconvert it do Dts core
BTW just now i render so different stuff with varius option but with no sound and the lag was missing but if i put DTS the lag shows but i have a thought now cause i have one mkv movie with dts sound 1080p and plays fine but other movies dont lay the sound mkv with dts lags and finally crash adn if i convert it to ts i have the small lag but on mkv file as i said plays fine with the dts sound and i dont know why.
All the files i playback them from my external to my tv and then with a cable to yamaha amp and tehn to home cinema speakers
Video playback problem after concatenated
By Zenjuro in forum EditingReplies: 6Last Post: 9th Jun 2014, 09:34 -
Is there any alternative to tsmuxerGui
By jack616 in forum Video ConversionReplies: 13Last Post: 30th Aug 2013, 11:43 -
tsmuxergui
By johnnyquest in forum Newbie / General discussionsReplies: 4Last Post: 13th Sep 2012, 06:21 -
Advantages of using M2TS over .TS with TSmuxerGUI
By jack616 in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2011, 12:35 -
MKV2VOB & TSMUXERGUI Won't Mux Entire Video
By FordGTGuy in forum Video ConversionReplies: 10Last Post: 11th May 2011, 13:14
