I have a source where the first minute recap on it has rainbows. I can get rid of them easily with a rainbow removing filter, but I do not wish to use that filter on the entire video, only the part with rainbows. I also want to denoise only that first part recap as well and not the rest of the video.
How can I go about properly using 2 filters for the first minute of the video, then not use those filters on the rest of video??
I tried using something like this, but for some reason when used like this, the derainbow filter does not seem to be working.
Thats about the only way I know how to do what I was originally asking, but I cant get the derainbower to work, even if I try a different one.Code:source=DGDecode_mpeg2source(".d2v file location here").QTGMC(preset="slow").crop(8, 2, -6, 0).LanczosResize(640,480) clip1=Trim(source, 0, 4866).lutderainbow().deen().santiag() clip2=Trim(source, 4867, 0).santiag() Return clip1 + clip2
When I simply use lutderainbow or another derainbow filter on the entire thing and not like I tried in the script above, they fully go away with no problem.
My problem here is, I need to use the derainbower before the deinterlacer for it to work, and if I stick the derainbower in the trim part of the script, its after the deinterlacer. If I stick the derainbower before the deinterlacer, it wont be in the trim part and is doing it to the entire video like I didnt want to begin with. (removing rainbows works this way though)
Is there another way to do what I am asking when using avisynth??
I use stickboy's ReplaceFramesSimple for this sort of thing. It's part of his RemapFrames. The syntax goes:
A=Last
B=A.Whatever Filter
ReplaceFramesSimple(A,B,Mappings=" [BeginFrame EndFrame]")
You can figure out the order for all the filtering you're doing.
two piece blank DVD media??
By yeoldmetalhead228 in forum MediaReplies: 4Last Post: 27th Jan 2015, 15:41 -
Extracting piece of guitar instrument from song
By bobybell in forum AudioReplies: 0Last Post: 13th Aug 2014, 17:23 -
Vegas 11, how to render just one audio track or piece?
By duhmez in forum EditingReplies: 3Last Post: 1st Sep 2013, 11:13 -
Video filter for reconstructing even/odd columns of video
By hyachts in forum Video ConversionReplies: 9Last Post: 28th Nov 2012, 13:08 -
best DVD recorder filter & ATI AIW filter
By VCRcomp in forum RestorationReplies: 1Last Post: 27th Jan 2011, 18:27
