I've got 7 avi files named 1 ,2,3, 4, 5, 6.avi
When I try to join 1-6 all at the same time WMP is giving me error as soon as I scrool to the part of the 2.avi
I try 1-3 and 4-6
but I can't join anything else to both of them.
The problem seem to be it can't go more than 2Gb.
(I think)
WMP can't read the file if it is more than 2Gb.
(I've tryed using PowerDVD, The Playa, Playcenter2, DivX Player..etc)
However, when I combine 1-6 (4Gb) and reencode it to 700MB
everything works like magic.
My spec: (if it matters)
1.4G T-Bird
256Mb DDR
Asus V8200 Deluxe
Plenty of HD space with DMA enabled
WMP is choking on all the information.
combine your (i assume) huffy avi files and play it but dont move the scroll bar and it will play all the way through showing that there are no errors but if you try to move the slider WMP tries to read to much to fast and returns a false error.
oh yeah also...
windows 9x and ME use the fat32 file system and does not support files over 2 gig
windows 2000 and XP(crap) when using the fat32 file system support up 4 gig files
windows 2000 and XP(crap) when using the NTFS file system supports large files. i dont recall the exact number of gigs but i have gone to 18 gig in a single file with no problems.peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose.
Funny Photo
By budwzr in forum Off topicReplies: 5Last Post: 7th Nov 2011, 08:01 -
Funny green screen
By timmythesaint in forum Newbie / General discussionsReplies: 18Last Post: 14th Apr 2009, 14:41 -
Now This Is Funny
By cracula in forum Off topicReplies: 2Last Post: 20th Mar 2008, 19:29 -
Funny joke programs..
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jan 2008, 07:17 -
funny colours in quicktime
By Shaorin in forum Newbie / General discussionsReplies: 3Last Post: 30th May 2007, 18:17
