Hi,
I have a video I cant play. All i see is a black screen. Mediainfo tells me is enconded with WMV1 but seems like I dont have it. I am on Windows 7 and I searched the web for this codec but cant find it. Any hint please?
Thank you.
				Results 1 to 30 of 54
	What player software are you using?
 Try another player like VLC or XBMC/KODI.
	Thanks for the answer. I use VLC but it cant play it either thats why I figured I have some codec missing. I havent disabled anything either so I really dont get it. I opened InstalledCodec to see what I have installed and WMV1 is not listed so I guess I don have it. Can I download it from somewhere?
	What about the encoder then? Maybe I dont have it and thats why the video is not being generated properly. Im attaching the video. Could you please check it?
 Thank you.
	469k is hardly big enough to generate any video.
 This could just be a stub to fool you to download adware/virus
	Hmm, I see. Then the problem might be with the encoder. See, this is a video generated from a game called FIFA 10. When you play a game it gives you an option to save it and export it to video but it has not advanced options such as choosing the enconder or so. So maybe if I get the correct encoder which I suppose is WMV1 the video will be encoded right. Is it possible to get this codec for download?
	The encoder should be with the game.
 Need to check the instructions about 'saving/exporting'.
	Unfortunately the instructions are not found anywhere. If anybody has them I would appreciate if they provide them but in the mean time the only thing I can do is trying to get the correct encoder.
	The video is encoded properly. The problem is that the encoder was given black frames to encode. And 0.33 fps is a very strange frame rate for a game recording. That's one frame every three seconds, a slideshow.
	But then why cant I find that codec in my codec list? This is what I have
 AC-3 ACM Codec x64
 AC3 Parser Filter
 AC3Filter
 ACM Wrapper
 Adobe PSI Parser
 AudioRecorder WAV Dest
 AudioRecorder Wave Form
 AVI Decompressor
 AVI Mux
 AVI Splitter
 AVI/WAV File Source
 Bandi Motion Jpeg
 Bandi MPEG-1 Audio
 Bandi MPEG-1 Video
 Bandisoft MPEG-1 Audio Decoder
 Bandisoft MPEG-1 Video Decoder
 BDA MPEG2 Transport Information Filter
 CBVA DMO wrapper filter
 Closed Captions Analysis Filter
 Color Space Converter
 DirectVobSub
 DirectVobSub (auto-loading version)
 Dump
 DV Muxer
 DV Splitter
 DV Video Decoder
 DVD Navigator
 DvPlayTee
 Enhanced Video Renderer
 ffdshow Audio Decoder
 ffdshow Audio Processor
 ffdshow DXVA Video Decoder
 ffdshow raw video filter
 ffdshow subtitles filter
 ffdshow Video Decoder
 File Source (Async.)
 File Source (URL)
 File stream renderer
 File writer
 Fraps Video Decompressor
 Fraunhofer IIS MPEG Layer-3 Codec
 Haali Matroska Muxer
 Haali Media Splitter
 Haali Media Splitter (AR)
 Haali Simple Media Splitter
 Haali Video Renderer
 Haali Video Sink
 Infinite Pin Tee Filter
 Internal Script Command Renderer
 iTV Data Capture filter
 iTV Data Sink
 LAV Audio Decoder
 LAV Splitter
 LAV Splitter Source
 LAV Video Decoder
 Line 21 Decoder
 Line 21 Decoder 2
 MainConcept (MCE) MPEG Encoder
 Media Center Extender Encryption Filter
 Microsoft AC3 Encoder
 Microsoft DTV-DVD Audio Decoder
 Microsoft DTV-DVD Video Decoder
 Microsoft MPEG-2 Audio Encoder
 Microsoft MPEG-2 Encoder
 Microsoft MPEG-2 Video Encoder
 Microsoft TV Captions Decoder
 Microsoft TV Subtitles Decoder
 MIDI Parser
 MJPEG Decompressor
 MPC - CDXA Reader
 MPC - FLV Source (Gabest)
 MPC - FLV Splitter (Gabest)
 MPEG Audio Decoder
 MPEG Video Decoder
 MPEG-2 Demultiplexer
 MPEG-2 Sections and Tables
 MPEG-2 Splitter
 MPEG-2 Video Stream Analyzer
 MPEG-I Stream Splitter
 msacm.imaadpcm
 msacm.msadpcm
 msacm.msg711
 msacm.msgsm610
 Multi-file Parser
 NetBridge
 Null Renderer
 Overlay Mixer
 Overlay Mixer2
 RDP DShow Redirection Filter
 SAMI (CC) Parser
 SampleGrabber
 SBE2FileScan
 SBE2MediaTypeProfile
 Screen Capture filter
 Smart Tee
 Sony Wave Hammer Surround
 SoundRecorder Null Renderer
 StreamBufferSink
 StreamBufferSink2
 StreamBufferSource
 TS Strider
 TSSourcePush
 VBI Codec
 VBI Surface Allocator
 VDP Renderer
 VGA 16 Color Ditherer
 vidc.i420
 VIDC.IYUV
 vidc.MP42
 vidc.MP43
 vidc.MPG4
 vidc.mrle
 vidc.msvc
 vidc.tscc
 VIDC.UYVY
 VIDC.YUY2
 VIDC.YVU9
 VIDC.YVYU
 Video Mixing Renderer 9
 Video Port Manager
 Video Renderer
 Video Renderer
 VPS Decoder
 Wave Parser
 WM ASF Reader
 WM ASF Writer
 WST Pager
 x264vfw - H.264/MPEG-4 AVC codec for x64
	If GSpot is correct WMV1 is not installed. But, as I said earlier, attempting to play a WMV1 encoded video with WMP should automatically download the codec if it's not already installed. What exactly is happening when you play the video? Do you get an error indicating a missing codec? Or do you get a black picture?
	I get a back picture just like you. But my point is that rather than the decoder what Im missing is the encoder and thats why I am getting all black videos.
	The official WMV1 (windows media 7) encoder comes with windows media encoder. FFmpeg also has a WMV1 encode/decode implementation
	The problem is not the encoder. Already been told TWICE that the encoder is built in to the program. That is logical since a program that offers such a feature could not expect any user to independently look for an external codec for this feature.
 So the issue is not the encoder but why you have saved blank frames.
 Of course your program works for Win7 but maybe not this feature. My hunch is that it concerns the video overlay and some OS's and the video card have to deal with that.
 So rather than use the built-in recorder try using a screen recorder or a program such as fraps. Report back with the results.Last edited by DB83; 3rd Jan 2016 at 04:46. Reason: Clarity
	If your OS is Windows 10, its have native Game Record feature. Very good.
 Claudio
	I have windows 7 and no, Im not using bandicam or whatsoever to record the game. Im using the in-game function that converses the saved game data directly into a video file. I have tried to record the screen with bandicam but it doesnt work on full screen mode, only windowed mode.
	Oh god, that was a no brainer. Anyway, I have tried that before but it doesnt work. I click the button with the controller icon and it says I must click the window with the game. I do so but when I hit record it says I havent selected the window.
	Instructions here:
 http://www.bandicam.com/product/how_to_record_desktop_screen/
 How to capture FS
	As I said previously, that doesnt work. When I go full screen the game takes over Windows so there is no way to initiate the recording. And even if I start recording before going full screen, I get nothing but a black image video. The only way I can record the game is if I record the screen when its in window mode but then it looks like shit because its not in full resolution.
  AAC codec: where I can find it?By marcorocchini in forum Newbie / General discussionsReplies: 18Last Post: 15th Jul 2014, 18:19
  I cannot find a xdcamhd422 codecBy marcorocchini in forum Newbie / General discussionsReplies: 8Last Post: 21st May 2014, 02:52
  find the video with better quality from codec settingsBy neo_rld in forum Video ConversionReplies: 13Last Post: 5th May 2014, 14:42
  WMP/xbox use metadata to find file for categorizing or playback?By isisism in forum Video ConversionReplies: 3Last Post: 2nd Mar 2014, 14:56
  Is it possible to find the actual stream URL for Air1 to play in WMP/VLC?By AshleyQuick in forum Video Streaming DownloadingReplies: 4Last Post: 4th Sep 2011, 23:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
